P0983 – Shift solenoid (SS) D -control circuit high
Last Updated 2016-01-12
P0983 | Shift solenoid (SS) D -control circuit high | Wiring, short to positive, shift solenoid, ECM/PCM/TCM |
What Does Code P0983 Mean?
During operation, the TCM checks the operation of the solenoid valves, consisting of a resistance check and speed sensor verification. If one of these checks fails, such as encountering an open circuit on Shift Solenoid D (SSF), the TCM disables that control circuit and sets DTC P0983 – Shift Solenoid D Control Circuit High in ECM memory.
What are the common causes of code P0983 ?
Depending on year, make, and model, DTC P0983 may have a couple of causes. Here are some of the most common.
- Stored Vehicles – Electrical problems are very common on vehicles with rodent infestations, because mice will chew through practically anything, including a wiring harness, to make room for their nests. Be on the lookout for nesting materials and droppings, which may point you directly to the open circuit.
- Poor Repairs – Major repairs, such as replacing a radiator or a cylinder head, may result in in a misrouted harness or poorly installed harness stays. If the wiring harness chafes on a moving part or is pulled taut, an open circuit condition could result from broken wires or poor connections.
- Burnt Out Solenoid – Typically, shift solenoids, particularly those inside the transmission, are well-protected from the elements, but open windings aren’t unheard of.
What are the symptoms of code P0983 ?
Because the TCM can no longer control Shift Solenoid D, one or more gears may not be accessible in “D” mode, which means that you will encounter drivability problems. Specific drivability problems depend entirely on how the manufacturer decided to use SSF. If SSF is used for one of the brakes, for example, two or more gears may be locked out, so you may experience poor acceleration (taking off in 2nd or 3rd gear) or high-revving before shifting (taking off in 1st gear and shifting into 5th). If the SSF is used for a pressure regulator or torque converter lockup, then the effects may be slightly less noticeable, such as harsh shifting, slow engagement, or poor cruising fuel economy (both from a free torque converter and from the ECM running in open loop).
How do you troubleshoot code P0983 ?
Because DTC P0983 describes an electrical problem, you’ll need a DVOM (digital volt-ohm meter) and wiring diagram to perform some circuit checks between the TCM and the transmission. You may be able to find wiring diagrams, specific to your vehicle, online, at an autoparts store, or even at your local dealership, if you ask nicely.
- Circuit Check – With the key off, use the EWD and DVOM to determine which circuits carry the signal for Shift Solenoid D. From the disconnected ECM or TCM connector, you should be able to perform a resistance check from the TCM to SSF, including the harness.
In the case of DTC P0983, we’d expect to find excessive resistance or an open circuit, in which case you will need to check the harness for continuity. Remove the transmission connector and put a short-pin across the appropriate terminals or to ground, then measure resistance at the TCM connector again. It should read 0 Ω. If not, repair the open circuit in the harness. If the harness is good, the last remaining part is the shift solenoid itself.
- Solenoid Check – Depending on make and model, SSF may or may not be located inside the transmission. If located outside, measure resistance right at its connector. If SSF is located inside, double check the resistance measurement at the transmission connector. If you measure an open circuit or no connection to ground, there is one more sub-harness that connects directly to the solenoid, and you will need to drop the transmission oil pan to access it.
Codes Related to P0983
I have a 2008 Toyota Sequoia and I have a code po983 and the obc2 tells me that I have high circuit on solenoid D. How do I know what is the one?
Estas dicas tem ajudado muito,
Peço para todos aqueles que possuem alguma informação técnica compartilham com os outros técnicos.
Saber não ocupa lugar, em sinar é uma virtude
Tengo una Captiva la esccanearla me dice tengo un alto voltaje de circuito de control de válvula selenoide de cambio 4
