P0982 – Shift solenoid (SS) D -control circuit low
Benjamin Jerew
Last Updated 2016-01-20
P0982 Shift solenoid (SS) D -control circuit low
Wiring, short to earth, shift solenoid, ECM/PCM/TCM
  1. What Does Code P0982 Mean?
  2. What are the common causes of code P0982 ?
  3. What are the symptoms of code P0982 ?
  4. How do you troubleshoot code P0982 ?
  5. Codes Related to P0982
  6. Get Help with P0982
During operation, the TCM checks the operation of the solenoid valves, consisting of a resistance check and speed sensor verification. If one of these checks fails, such as encountering a short circuit on Shift Solenoid D (SSD), the TCM disables that control circuit and sets DTC P0982 – Shift Solenoid F Control Circuit Low in ECM memory.
shift-solenoid
Depending on year, make, and model, DTC P0982 may have a couple of causes. Here are some of the most common.
  • Stored Vehicles – Electrical problems are very common on vehicles with rodent infestations, because mice will chew through practically anything, including a wiring harness, to make room for their nests. Be on the lookout for nesting materials and droppings, which may point you directly to the short circuit.
  • Poor Repairs – Major repairs, such as replacing a radiator or a cylinder head, may result in in a misrouted harness or poorly installed harness stays. If the wiring harness chafes on a moving part or is pulled taut, a short circuit condition could result from exposed wires or poor connections.
Because the TCM can no longer control Shift Solenoid D, one or more gears may not be accessible in “D” mode, which means that you will encounter drivability problems. Specific drivability problems depend entirely on how the manufacturer decided to use SSD. If SSD is used for one of the brakes, for example, two or more gears may be locked out, so you may experience poor acceleration (taking off in 2nd or 3rd gear) or high-revving before shifting (taking off in 1st gear and shifting into 5th). If the SSD is used for a pressure regulator or torque converter lockup, then the effects may be slightly less noticeable, such as harsh shifting, slow engagement, or poor cruising fuel economy (both from a free torque converter and from the ECM running in open loop).
Because DTC P0982 describes an electrical problem, you’ll need a DVOM (digital volt-ohm meter) and wiring diagram to perform some circuit checks between the TCM and the transmission. You may be able to find wiring diagrams, specific to your vehicle, online, at an autoparts store, or even at your local dealership, if you ask nicely.
  1. Harness Check – First, check the wiring harness, starting from the ECM and TCM and following it to the transmission. Check for signs of damage, such as from rodent infestation or a poorly-routed harness following other repairs. A chafed wire harness can easily cause open circuit or short circuit problems.
  1. Circuit Check – With the key off, use the EWD and DVOM to determine which circuits carry the signal for Shift Solenoid D. From the disconnected ECM or TCM connector, you should be able to perform a resistance check from the TCM to SSD, including the harness.
SS.1452191300
In the case of DTC P0982, we’d expect to find low resistance or a short circuit, in which case you will need to check the harness for resistance. Remove the transmission connector and then measure resistance at the TCM connector. It should read 10 – 20 Ω. If not, repair the short circuit in the harness. If the harness is good, the last remaining part is the shift solenoid itself.
c178086e05
  1. Solenoid Check – Depending on make and model, SSD may or may not be located inside the transmission. If located outside, measure resistance right at its connector. If SSD is located inside, double check the resistance measurement at the transmission connector. If you measure an open circuit or no connection to ground, there is one more sub-harness that connects directly to the solenoid, and you will need to drop the transmission oil pan to access it.
c160564e01
  • DTC P0972 Shift Solenoid “A” Control Circuit Range/Performance
  • DTC P0974 Shift Solenoid “A” Control Circuit High
  • DTC P0975 Shift Solenoid “B” Control Circuit Range/Performance
  • DTC P0976 Shift Solenoid “B” Control Circuit Low
  • DTC P0977 Shift Solenoid “B” Control Circuit High
  • DTC P0978 Shift Solenoid “C” Control Circuit Range/Performance
  • DTC P0979 Shift Solenoid “C” Control Circuit Low
  • DTC P0980 Shift Solenoid “C” Control Circuit High
  • DTC P0981 Shift Solenoid “D” Control Circuit Range/Performance
  • DTC P0983 Shift Solenoid “D” Control Circuit High
  • DTC P0984 Shift Solenoid “E” Control Circuit Range/Performance
  • DTC P0985 Shift Solenoid “E” Control Circuit Low
  • DTC P0986 Shift Solenoid “E” Control Circuit High
  • DTC P0997 Shift Solenoid “F” Control Circuit Range/Performance
  • DTC P0998 Shift Solenoid “F” Control Circuit Low
  • DTC P0999 Shift Solenoid “F” Control Circuit High
