P0976 – Shift solenoid (SS) B -control circuit low
Last Updated 2017-01-26
P0976 | Shift solenoid (SS) B -control circuit low | Wiring, short to earth, shift solenoid, ECM/PCM/TCM |
What Does Code P0976 Mean?
During operation, the TCM checks the operation of the solenoid valves, consisting of a resistance check and speed sensor verification. If one of these checks fails, such as encountering a short circuit on Shift Solenoid B (SSB), the TCM disables that control circuit and sets DTC P0976 – Shift Solenoid B Control Circuit Low in ECM memory.
What are the common causes of code P0976 ?
Depending on year, make, and model, DTC P0976 may have a couple of causes. Here are some of the most common.
- Stored Vehicles – Electrical problems are very common on vehicles with rodent infestations, because mice will chew through practically anything, including a wiring harness, to make room for their nests. Be on the lookout for nesting materials and droppings, which may point you directly to the short circuit.
- Poor Repairs – Major repairs, such as replacing a radiator or a cylinder head, may result in in a misrouted harness or poorly installed harness stays. If the wiring harness chafes on a moving part or is pulled taut, a short circuit condition could result from exposed wires or poor connections.
What are the symptoms of code P0976 ?
Because the TCM can no longer control Shift Solenoid B, one or more gears may not be accessible in “D” mode, which means that you will encounter drivability problems. Specific drivability problems depend entirely on how the manufacturer decided to use SSB. If SSB is used for one of the brakes, for example, two or more gears may be locked out, so you may experience poor acceleration (taking off in 2nd or 3rd gear) or high-revving before shifting (taking off in 1st gear and shifting into 5th). If the SSB is used for a pressure regulator or torque converter lockup, then the effects may be slightly less noticeable, such as harsh shifting, slow engagement, or poor cruising fuel economy (both from a free torque converter and from the ECM running in open loop).
How do you troubleshoot code P0976 ?
Because DTC P0976 describes an electrical problem, you’ll need a DVOM (digital volt-ohm meter) and wiring diagram to perform some circuit checks between the TCM and the transmission. You may be able to find wiring diagrams, specific to your vehicle, online, at an autoparts store, or even at your local dealership, if you ask nicely.
- Circuit Check – With the key off, use the EWD and DVOM to determine which circuits carry the signal for Shift Solenoid B. From the disconnected ECM or TCM connector, you should be able to perform a resistance check from the TCM to SSB, including the harness.
In the case of DTC P0976, we’d expect to find low resistance or a short circuit, in which case you will need to check the harness for resistance. Remove the transmission connector and then measure resistance at the TCM connector. It should read 10 – 20 Ω. If not, repair the short circuit in the harness. If the harness is good, the last remaining part is the shift solenoid itself.
- Solenoid Check – Depending on make and model, SSB may or may not be located inside the transmission. If located outside, measure resistance right at its connector. If SSB is located inside, double check the resistance measurement at the transmission connector. If you measure an open circuit or no connection to ground, there is one more sub-harness that connects directly to the solenoid, and you will need to drop the transmission oil pan to access it.
Codes Related to P0976
Where can I locate shift solenoid B for 2009 Chevy aveo
