P0912 – Transmission gate select actuator -circuit low
Last Updated 2015-11-18
P0912 | Transmission gate select actuator -circuit low | Wiring, short to earth, transmission gate select actuator, ECM/PCM/TCM |
Where is this located on a audi a4 2004
Edwin-
As far as I can tell, this is referring to the switches in the gate shifter itself, right at the shift lever inside the car.
