P0851 – Park/neutral position (PNP) switch -input circuit low
Benjamin Jerew
Last Updated 2017-07-18
P0851 Park/neutral position (PNP) switch -input circuit low
Wiring, short to earth, PNP switch, ECM/PCM/TCM
  1. What Does Code P0851 Mean?
  2. What are the common causes of code P0851 ?
  3. What are the symptoms of code P0851 ?
  4. How do you troubleshoot code P0851 ?
  5. Codes Related to P0851
  6. Get Help with P0851
For the engine and transmission to work together, the ECM and TCM (engine and transmission control modules) use a number of sensors to monitor the engine and transmission, such as shaft speed, line pressure, or throttle position. To determine shift patterns, the TCM monitors the shift position switch, sometimes called the PRNDL switch on automatic transmissions, and park/neutral position (PNP) switch. They may even be integrated in the same unit.
The signal from the shift position switch and PNP switch depend on the position of the shift lever. The PNP signal is used to enable or disable engine starting and cruise control. For example, when the transmission is in park or neutral, the PNP switch sends an “ON” signal to the ECM, which enables engine starting and disables cruise control. If the transmission is shifted out of park or neutral, the PNP switch sends an “OFF” signal to the ECM, which disables engine starting and enables cruise control. On some manual-transmission vehicles, the PNP switch may also be directly connected to the starter circuit, functioning in the same manner to enable or disable starting.
The ECM continually monitors the PNP switch, comparing its signal to expected values. For example, driving at 30 mph, the ECM expects to see the PNP switch in the “OFF” position. Similarly, the ECM expects to see the PNP switch “ON” at the same time as the PRNDL switch is in P or N. If the ECM detects PNP signals with low voltage, it sets a diagnostic trouble code, DTC P0851 – Park Neutral Position (PNP) Switch Input Circuit Low, in system memory.
160863d1355379619-engine-racing-neutral-park-mystery-neutral-safety-switch-continuity-check
Depending on year, make, and model, DTC P0851 may have number of causes. Here are some of the most common.
  • PNP Switch Fault – Exposed to the elements, internal corrosion is always a possibility. Corrosion or water entry can short-circuit the switch or cause excessive resistance.
  • Alignment – On some transmissions, the PNP or PRNDL switch may need to be aligned properly. On Toyota vehicles, for example, there is a “Neutral Line” on the switch which lines up with the transmission in the neutral position. Misalignment can lead to conflicting signals at the ECM.
  • Poor Remote Starter Installation – Some aftermarket remote starters may require tapping into the PNP circuit. Improper installation, such as by-passing the switch or creating a short circuit, may interrupt the signal at the ECM.
Depending on failure mode, the MIL (malfunction indicator lamp) may or may not be illuminated, and engine starting may be locked out. Usually, with this DTC in memory, cruise control is locked out. If you can start the vehicle, you may not notice any drivability symptoms.
hw2673_1.339
The PNP switch is a simple on-off switch, with a single input and output. The PNP switch has a 12 V input, output switching between 0 V and 12 V, depending on whether the transmission is put in Park/Neutral or not. (Vehicles with an automatic transmission and a PRNDL switch perform the same switching, but across more outputs: Park, Reverse, Neutral, Drive, and 3, 2, or Low, depending on manufacturer. In this case, we’re interested in the Park and Neutral outputs.) A DVOM (digital volt-ohm meter) or test light is usually enough to diagnose the PNP switch.
  • PNP or PRNDL Switch Check – You may have to lift the vehicle to access the PNP or PRNDL switch. Always follow safe lifting and holding practices, set the parking brake, and chock the wheels.
    • Disconnect the switch and check for continuity in different shift positions. A simple PNP switch should have continuity across the two terminals, when the transmission lever is put in park or neutral. Check again with the transmission in reverse, drive, or any gear, and you should read an open circuit.
Similarly, a PRNDL switch should only have continuity across two terminals in Park and across two terminals in Neutral. For example, one Toyota PRNDL switch has continuity across pins 5 & 6 when the transmission is in Park or Neutral, and an open circuit across pins 5 & 6 in any other position.
      • If the switch never changes continuity, suspect a fault in the switch itself.
      • If the switch changes continuity, but in the wrong transmission position, the switch may not be installed correctly.
      • If the switch changes continuity in the right positions, go on to “Electrical Check.”
  •  Electrical Check – You will need an electrical wiring diagram (EWD), specific to your vehicle, to determine what voltage should be found where and when. Some PNP switches get their power from the ECM or TCM, while others get their power from the starter command circuit. Turn the key on and reconnect the PNP switch
    • Check for input voltage, usually 12 V, to the PNP switch. If voltage isn’t as specified, follow the EWD back to its source, which may be a fuse or ECM/TCM.
    • Check for output voltage, again usually 12 V, from the PNP switch.
      • If voltage isn’t as specified, suspect excessive internal resistance or improper installation. Recheck switch alignment or replace the sensor.
      • If voltage is good at the switch, suspect a fault between the PNP switch and ECM. Check wiring harnesses for damage, chafing, or misrouting. Check connectors for bent or backed-out pins, corrosion, or water entry. Disconnect the PNP and ECM connectors and check for continuity or short circuits. Repair as necessary.
SS.1463002709
  • P0704 Clutch Switch Input Circuit Malfunction
  • P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input)
  • P0706 Transmission Range Sensor Circuit Range/Performance
  • P0707 Transmission Range Sensor Circuit Low Input
  • P0708 Transmission Range Sensor Circuit High Input
  • P0709 Transmission Range Sensor Circuit Intermittent
  • P0850 Park/Neutral Switch Input Circuit
  • P0851 Park/Neutral Switch Input Circuit Low
  • P0852 Park/Neutral Switch Input Circuit High
  • P0805 Clutch Position Sensor Circuit
  • P0806 Clutch Position Sensor Circuit Range/Performance
  • P0807 Clutch Position Sensor Circuit Low
  • P0808 Clutch Position Sensor Circuit High
  • P0809 Clutch Position Sensor Circuit Intermittent
  • P0810 Clutch Position Control Error
  • P0817 Starter Disable Circuit
  • P0830 Clutch Pedal Switch “A” Circuit
  • P0831 Clutch Pedal Switch “A” Circuit Low
  • P0832 Clutch Pedal Switch “A” Circuit High
  • P0833 Clutch Pedal Switch “B” Circuit
  • P0834 Clutch Pedal Switch “B” Circuit Low
  • P0835 Clutch Pedal Switch “B” Circuit High
  • P0893 Multiple Gears Engaged
