P0791 – Intermediate shaft speed sensor -circuit malfunction
P0791 | Intermediate shaft speed sensor -circuit malfunction (Buy Part On Amazon) | Wiring, poor connection, intermediate shaft speed sensor, ECM/PCM!TCM |
- What Does Code P0791 Mean?
- What are the common causes of code P0791 ?
- What are the symptoms of code P0791 ?
- Codes Related to P0791
- Get Help with P0791
DTC P0791 sets when the PCM/TCM has received an input signal from the transmission intermediate shaft speed sensor circuit that is either irrational, erratic, or in some way incorrect. Without a usable output speed signal the transmission cannot provide a proper shift strategy
- Defective intermediate shaft speed sensor
- Defective output speed sensor, or input speed sensor
- Shorted, open, corroded, or damaged wiring circuits or connectors
- Defective shift solenoid
- Defective engine drivability sensors, like the ECT (Engine Coolant temperature),
- Contaminated transmission fluid that restricts flow, defective valve body
- Defective PCM
- MIL (Malfunction Indicator Lamp [Check Engine & Service Engine Soon])lights on with stored historical P0791
- Harsh shift, failure to shift
- Decrease in fuel economy
- Speedometer may fluctuate or not work
- Engine may stall when coming to a stop, engine misfire, sag, stall, or hesitation,
- There may be no symptoms
I have a 05 F-250 gas burner that throws this code and goes into limp mode around third gear and will stay in limp mode. Shut truck off and start and it goes away untill third gear
I am getting 3 codes from my trans. po715,po720 and po791 this is a 2006 f250 and is stuck in limp mode
