P0790 – Transmission mode selection switch -circuit malfunction
P0790 | Transmission mode selection switch -circuit malfunction (Buy Part On Amazon) | Wiring, transmission mode selection switch, ECM/PCM!TCM |
- What Does Code P0790 Mean?
- What are the common causes of code P0790 ?
- What are the symptoms of code P0790 ?
- Codes Related to P0790
- Get Help with P0790
DTC P0790 sets when the PCM/TCM has detected a malfunction in the electrical circuit of the transmission mode selector. The switch, system wiring and connectors, and mode actuator are all included in this circuit.
The transmission range (TR) switch or mode selector, also called the manual lever position (MLP) sensor, is used as an input to the PCM/TCM, which indicates the drive range requested by the driver. The transmission range switch is usually located on the outside of the case on the transmission/transaxle housing and attached to the shifter. As the gear range selector is moved, TR switch can make a variety of switch connections for each gear range. These inputs allow the TCM to determine which gear range has been selected. The switch is used by the TCM to
- Keep the engine from starting in any gear position except park or neutral
- Allow a progressive 1–2–3–4 shift sequence in drive
- Limit upshifts in manual ranges
- Operate the backup lights in reverse
- Water contamination of the transmission mode switch
- Open or shorted electrical wiring, damaged, corroded, or disconnected wiring or connectors
- MIL (Malfunction Indicator Lamp [Check Engine & Service Engine Soon])lights on with stored historical P0790
- There may be no distinguishable symptoms
- Torque converter clutch will not function
- In some applications, the overdrive light may flash
- TCM/PCM may also enter “limp-in” mode when this code is stored with harsh shifts
None
Buenos dias,me sale.el fallo 790,algo relacionado con,la temperatura del coche,la aguja de la temperatura veces me sube como un,balanseo hacia arriba se enciende la luz roja de stop pero todo esto es un,balanceo rapido subiendo,y,vajando al,instnte.,,¿Cual seria su areglo o como lo hacia?gracias.
Ok
