P0780 – Gear selection -shift malfunction
P0780 | Gear selection -shift malfunction (Buy Part On Amazon) | Wiring, TR sensor, shift solenoids, transmission mechanical fault |
- What Does Code P0780 Mean?
- What are the common causes of code P0780 ?
- What are the symptoms of code P0780 ?
- Codes Related to P0780
- Get Help with P0780
DTC P0780: The TCM (Transmission Control Module) or PCM (powertrain control module) monitors the transmission mechanical shifting through various sensors. This malfunction is detected when the transmission does not shift as instructed by the TCM. This is not caused by electrical malfunction (circuits open or shorted) but by mechanical malfunction such as control valve sticking, improper solenoid valve operation, etc.
The TCM or PCM has detected an abnormality in shift procedure. The TCM/PCM controlled automatic transmission uses shift solenoids to manage the transfer of fluid between hydraulic circuits and actuate a change in transmission gear ratio. Varying gear ratios are needed to increase and decrease vehicle speed, maximize engine performance, and optimize fuel efficiency.
- Low transmission fluid, dirty or contaminated transmission fluid
- Hydraulic blockages inside the internal transmission fluid passages
- Mechanical internal transmission failures
- Defective shift solenoid
- Shifting solenoid valve harness is open or shorted
- Shifting solenoid valve circuit poor electrical connection
- Defective PCM or TCM
- MIL (Malfunction Indicator Lamp [Check Engine & Service Engine Soon])lights on with stored historical P0780
- Harsh shift, failure to shift, failure of the transmission to shift from (or into) any particular gear.
- Slippage, transmission overheating
- Decreased fuel efficiency
- Other shift solenoid codes often accompany this code
- TCM/PCM may also enter “limp-in” mode when this code is stored.
My wife’s CRV started losing the feel in the shifter when changing gear. It still went into gear and displayed the gear on the dash. It was still drivable but when her battery kept dying she had enough.
When I asked her the last time the transmission was checked she didn’t have a clue. Wouldn’t it be wonderful if I put some new fluid in and it works normal?
A guy can dream. 😉
Mi carro es una honda odissey 2001
Cuando la condusco golpea la 2da ya cambie las selenoides pero siempre
Golpea el cambio cuando está caliente
En frío no lo golpea
