P0775 – Pressure control solenoid B -malfunction
Last Updated 2016-01-15
Ed.D, PhD Philosophy, BSME
P0775 | Pressure control solenoid B -malfunction | Pressure control solenoid |
What Does Code P0775 Mean?
The transmission’s hydraulic pump pressure regulator valve is controlled by the pressure regulator valve that is controlled by a pulse-width-modulated solenoid called Electronic pressure control (EPC) or Pressure control solenoid (PCS) or Variable force solenoid (VFS) or Force motor. This device is normally closed, which results in high regulated pressure. Current (a maximum of about 1 ampere) allows the solenoid to open, which reduces the regulated pressure. This pressure solenoid is PWM (Pulse Width Modulated) so the higher the duty cycle, the more current and the lower the pressure and the lower the duty cycle, the less the current, the higher the pressure.
The line pressure solenoid valve regulates the oil pump discharge pressure to suit the driving condition in response to a signal sent from the TCM (Transmission Control Module). The pressure control (PC) solenoid valve is an electronic device that regulates transmission line pressure based on the current flow through its coil winding. The magnetic field produced by the coil moves the solenoid’s internal valve which varies pressure to the pressure regulator valve. The PCM/TCM controls the PC solenoid valve by applying a varying amount of amperage to the solenoid. The applied amperage can vary from 0.1 to 1.1 amps. Low amperage, 0.1 amp, indicates high line pressure. High amperage, 1.1 amps, indicates low line pressure. The duty cycle of the PC solenoid valve is expressed as a percentage of energized ON time. Zero percent indicates zero ON time, non-energized, or no current flow. Approximately 60 percent at idle indicates maximum ON time, energized, or high current flow. The PCM/TCM determines the appropriate line pressure for a given load by comparing the throttle, engine speed and other inputs. Figure 1 shows the pressure control solenoid wiring diagram.
DTC P0775 sets when the PCM detects a continuous open or short in the pressure control solenoid valve circuit.
Figure 1 Pressure Control Solenoid Circuit
What are the common causes of code P0775 ?
- Low or contaminated transmission fluid
- Hydraulic fluid passage blockages inside transmission
- Mechanical internal transmission failures
- Faulty pressure control solenoid
- Solenoid harness or connectors
- Solenoid circuit is open or shorted
- Defective PCM/TCM in very rare cases
What are the symptoms of code P0775 ?
- Transmission will not shift gears
- Slippage, transmission overheating, decreased fuel efficiency
- PCM/TCM may also enter “limp-in” mode when this code is stored
2005 Dodge Dakota 4×4 V-6 Po775 code ,Also P1775 ,P0732 codes truck has 100,000 miles I Am Machine Repairmen Just need To Point
Need some More Info ,Like Location of solenoid,
