P0760 – Shift solenoid (SS) C -circuit malfunction
Avatar photo
Last Updated 2021-12-08
P0760 Shift solenoid (SS) C -circuit malfunction
Wiring, shift solenoid, ECM/PCM/TCM
  1. What Does Code P0760 Mean?
  2. Where is the P0760 sensor located?
  3. What are the common causes of code P0760 ?
  4. What are the symptoms of code P0760 ?
  5. Get Help with P0760
OBD II fault code P0760 is a generic trouble code that is defined as, “Shift Solenoid “C”, and is set when the PCM (Powertrain Control Module) detects a failure, defect, malfunction, or an undefined problem in the shift solenoid labeled “C”, or in one or more control circuits that are associated with the shift solenoid labeled “C”.
NOTE:  Vehicle manufacturers do not follow a standard convention in how they label the shift solenoids in their transmissions. Therefore, both the function of shift solenoid “C”, and the symptoms of defects in shift solenoid “C” may differ between vehicle makes and models, as well as between transmission types/designs.
While the basic operating principles of automatic transmissions have not changed significantly over the past several decades, the complexity and sophistication of transmission control systems have changed greatly. We need not delve into the complexities of these systems here, beyond saying that all modern automatic transmissions now use computer-controlled solenoids to direct and change the flow of pressurized transmission fluid.
In practice, these solenoids are known as “shift solenoids” since they control the flow of fluid that acts on various components in the transmission. For instance, if the PCM or TCM (Transmission Control Module) commands a gearshift, it accomplishes the shift by closing one solenoid, and opening another to direct pressurized fluid into another hydraulic circuit in the valve body.
Thus, when one solenoid is closed, pressure is removed from the clutches that kept, say, first gear engaged, which disengages first gear. By opening the next solenoid in the shift pattern, pressurized fluid enters another circuit through a series of valves, which engages second gear. In a fully functional transmission control system, the PCM/TCM obtains input data from several engine sensors, including (among several others) the-
  • engine speed sensor
  • vehicle speed sensor
  • throttle position sensor
  • throttle pedal position sensor
  • steering angle sensor
– to calculate appropriate shift points. While these calculations are based primarily on the current engine speed and load, other factors include the current operating conditions, driving style, and the currently selected operating mode, i.e., Economy, Sport, or Performance.
However, shift solenoid failures are fairly common across all manufacturers and transmission designs, so when such a failure occurs, the PCM/TCM will recognize that it cannot control the transmission effectively. When this happens, the PCM/TCM will set an appropriate trouble code, and depending on the vehicle, may or may not illuminate a warning light.
Note though that depending on both the nature of the failure and the vehicle, the PCM/TCM may initiate a fail-safe or limp mode as a precautionary measure that will typically persist until the fault is corrected.
This image shows the location (circled) of shift solenoid “C” in the valve body of a Mazda CX7 application.
Note that both the appearance of valve bodies and the arrangement of shift solenoids on valve bodies vary greatly between vehicle makes and models as well as between transmission designs/types. Moreover, since valve bodies are located inside automatic transmissions, we do not recommend that non-professional mechanics attempt to diagnose and/or repair shift solenoid-related issues.
The most common causes of code P0760 are largely similar across all applications, and could include one or more of the following-
  • Defective shift solenoid “C”
  • Damaged, burnt, shorted, corroded, or disconnected wiring and/or electrical connector both inside and outside the transmission
  • Localized blockages or restrictions in the valve body that affect the operation of shift solenoid “C”
  • Defects or malfunction in either (or both) the PCM and TCM, but note that this is very rare since these kinds of failures typically affect the operation of the entire transmission
NOTE: Issues like low transmission fluid levels and/or low fluid pressure will usually affect all transmission components that depend on pressurized fluid to work as designed, as opposed to affecting just one shift solenoid.
Depending on the function of shift solenoid “C” in any given transmission, the symptoms of code P0760 could include one or more of the following-
  • Stored trouble code and possibly an illuminated warning light
  • The transmission may “slip” in one or more gears
  • The transmission may not select one or more gears, or in some cases, it may select no gears at all
  • The transmission may be stuck in one gear
  • Some or all gear shifts may be harsh, erratic, or unpredictable
  • The transmission may overheat
  • Fuel consumption may increase noticeably
  • The engine may stall unpredictably at low engine speeds, such as when the vehicle comes to a stop
  • In some cases, the transmission may be locked into a fail-safe or limp mode, which will persist until the fault is corrected
