P0753 – Shift solenoid (SS) A -electrical
Last Updated 2016-10-19
Red Seal Certified Mechanic
P0753 | Shift solenoid (SS) A -electrical | Wiring, shift solenoid, ECM/PCM!TCM |
What Does Code P0753 Mean?
Shift solenoid are responsible for shifting your transmission’s gears. It uses pulse width modulated solenoid to control fluid pressure/flow. Your transmission may have multiple shift solenoids. They are part of the valve body in the transmission. The transmission control module TCM monitors a combination of sensors within the system (speed sensors, throttle position sensor TPS, etc..) in conjunction with the powertrain control module and other sensors to determine the shifting of the transmission. It modifies the signal to Shift solenoid to adjust accordingly. Given that the code indicates electrical, a good place to start with, is on the electrical side of things. Accessing the shift solenoids in the transmission can be very invasive, better left to a transmission repair facility. The PCM and TCM compares and monitors all the sensors involved with the system and if they detect anything out of specified values they throw the light on the instrument cluster. Transmission repairs can get expensive so you will want to make sure to cover the basics before jumping to any conclusions.
What are the common causes of code P0753 ?
- Dirty transmission fluid
- Transmission control module
- Shift solenoid defective
- Shift solenoid circuit open/short
- Bad grounds
- ECM
- Corroded connections or pins
- Wiring issue (corrosion, chafed, melted)
What are the symptoms of code P0753 ?
- Not shifting
- Drivability issues
- Harsh shifts
- Erratic shifts
- High engine RPMs
How do you troubleshoot code P0753 ?
BASIC STEP #1:
Check your fluid. Verify when the last fluid change was done and refer to service manual for service intervals. If beyond interval, you should replace the oil, if not, verify level and condition. If you do replace the fluid in the transmission and you will have the oil pan off, it would be a good idea to check the shift solenoid circuit if accessible. Refer to service manual and other troubleshooting steps.
NOTE: ALWAYS use specific automatic transmission fluid for make/model. This step is important in preventing any serious damage to transmission internals. A mistake here could potentially cost you LOTS of $$.
BASIC STEP #2:
Check shift solenoid circuit. Refer to service manual for connector locations. You may need to unplug several connectors in order to check circuit integrity. Make sure to disconnect battery before proceeding. Depending on the particular system layout you may need to to check circuit between solenoid to transmission control module and between powertrain control module and TCM. Make sure to perform basic circuit testing (i.e: open, short to power or ground, high resistance). Refer to manual for specific desired values. Perform necessary repairs and test drive. If everything checked out and code is still active, proceed to next step.
BASIC STEP #2:
Check shift solenoid. This procedure varies between manufacturer and specific system operation but generally speaking, you need a OBD2 scanner with monitoring capabilities to verify solenoid functionality. You may be able to turn solenoid on/off and monitor status on scanner to determine solenoid performance. Refer to service manual for procedure. Keep in mind you may even need to use a manufacturer specific OBD scanner to access these functionality tests. Sometimes you need to bring vehicle to repair facility to get accurate diagnosis.
BASIC STEP #3:
Replace shift solenoid. If you’ve referred to service manual and you are confident in your capabilities, you may be able to replace solenoid without too much trouble. Depending on the price of shift solenoid and accessibility, it may be worth a try but keep in mind you may be guessing at this point. Make sure to replace with new fluid if you haven’t already , to prevent any damage to new sensor. It is imperative to keep sensor clean of debris before installing to prevent any malfunctions.
BASIC STEP #4:
If you’ve replaced sensor, the fluid and the circuits check out, it’s time to check PCM and TCM operation. Refer to specific manufacturer for procedures. This may be the time to bring to a reputable transmission repair facility to diagnose and repair issue with transmission. Make sure to let them know if you’ve replaced fluid , to prevent any mix up. Good luck!
Codes Related to P0753
- P0750 Shift solenoid (SS) A -circuit malfunction
- P0751 Shift solenoid (SS) A -performance or stuck off
- P0752 Shift solenoid (SS) A -stuck on
- P0754 Shift solenoid (SS) A -circuit intermittent
- P0755 Shift solenoid (SS) B -circuit malfunction
- P0756 Shift solenoid (SS) B -performance or stuck off
BAT Team Discussions for P0753
- 99 Silverado Transmission Woes.
Right on with the codes, P0753. Looks like a shift solenoid may be going. Is this something I can do myself, or are there other possibilities? Thanks, any suggestions are appreciated. Josh... - 98 Dodge Ram 1500 van fuel pump wiring
This is a 98 dodge ram 1500 van 5. 2L auto trans. I used an actron CP9145 scan tool if that matters: 1/3: P0545 Mod$D1 Exhaust Gas Temp Sensor Circuit Low (bank 1 sensor 1) 2/3: P0753 Mod$D1 Shift Solenoid A circuit Electrical 3/3: P0463 Mod$D1 Fuel Level Sensor A Circuit High Input I/M red... - Cavalier Sudden Transmission Failure
Hello boys and girls, I hope I'm doing this right. . My car is a 2002 Cavalier Z24 (I believe it's called an LS Sport in the United States, it is still called the Z24 up here in the Great White North ;D). She's my first car and she currently has 140,000 kilometers (thats 87000 miles) and is equip... - transmission locked in park
I work with a family that has a ‘98 Grand AM SE 2. 4L (118,000 miles) that last October experienced a significant ‘change’ with lockup in Park and restrictions on shifting. The family has since been using the unlock lever beneath the shifter to retain use of the car. Before the ‘change’, the c... - 46re wont shift out of 1st
hey kev2. last night we ran a scan from a snap on scanner and only the p1899 came up. I had my dad do the key on off three times deal and i have a P0753,P1765, and P1899. does this make sence of the situation?...
My 1997 GMC Sierra codes are PO740..753..785.. and P1860 my fluid was about a quart low..I just bought the truck and it was doing good till I started to leave my house and check engine light came on and it seem like it was trying to take off in high gear..im gonna change fluid and filter does anyone know if a quart low would cause these codes and make it act that way?
Terry-
There’s a TSB for this problem that seems like it applies perfectly to your vehicle. The problem includes multiple transmission DTCs, and transmission suck in third gear. The problem is probably in the ignition switch, which seemed to have issues where it wouldn’t power the transmission solenoids. The transmission controller only grounds solenoids, but power is provided by the ignition switch. Information is as follows:
1997-1999 GMC Sierra, Suburban, Yukon
GM has issued a technical service bulletin 01-07-30-002C for the vehicles listed below. GM has advised that the most likely cause for a check engine light and trouble codes P0740, P0753, P0758, P0785, and P1860 may be a faulty ignition switch that causes an open circuit to the transmission. Other symptoms include a Check Engine light on, transmission stuck in third gear, and an instrument cluster that doesn’t work.
GM advises that you start your diagnostics by turning the key to the RUN position and checking for battery voltage at the transmission fuse: If you don’t get battery voltage, replace the ignition switch, which is located at the base of the steering column. It’s either Trans Fuse 20 or 24.
I hope this helps.
