P0740 – Torque converter clutch (TCC) solenoid – circuit malfunction
Last Updated 2016-08-23
Ed.D, PhD Philosophy, BSME
P0740 | Torque converter clutch (TCC) solenoid - circuit malfunction (Buy Part On Amazon) | Wiring, TCC solenoid, ECM/PCM/TCM |
What Does Code P0740 Mean?
DTC P0745: When the transmission solenoid malfunctions, in most cases the problem is not the electrical part of the solenoid; the problem is generally foreign material obstructing the mechanical function of the solenoid or the flow of the fluid through the transmission valve body. The line pressure solenoid valve regulates the oil pump discharge pressure to suit the driving condition in response to a signal sent from the TCM (Transmission Control Module) or PCM (Powertrain Control Module).
DTC P0745 sets when the PCM or TCM has detected an abnormality in the electronic pressure control solenoid circuit. Computer controlled automatic transmissions use variable amounts of hydraulic pressure to provide shifting and TCC (torque converter clutch) operation.
What are the common causes of code P0740 ?
- Low, dirty or contaminated transmission fluid If the transmission fluid is very dirty, it is recommend changing the transmission fluid and if possible removing the transmission pan for further diagnosis.
- Excessive debris or metal particles on the transmission pan could be an indication that there is a transmission mechanical failure and that the transmission will need to be rebuilt or replaced.
- Defective pressure control solenoid
- Line pressure solenoid valve harness is open or shorted
- Line pressure solenoid valve circuit poor electrical connection
- Fluid blockages inside the transmission fluid passages
- Mechanical internal transmission failures
- Defective PCM or TCM but this is rare
What are the symptoms of code P0740 ?
- MIL (Malfunction Indicator Lamp [Check Engine & Service Engine Soon])lights on with stored historical P0745
- TCC does engage/disengage
- Disabled shifting function with engine stall when coming to a stop
- Harsh shifting, transmission slippage, transmission overheating
- Fuel efficiency concern
Codes Related to P0740
- Transmission slippage codes often accompany this code like DTC P0894
I have a 1998 Chevrolet blaze 4 by4 the Engle light stay on but every shift is good as new what could be the problem
