P0730 – Incorrect gear ratio
Last Updated 2016-01-17
Ed.D, PhD Philosophy, BSME
P0730 | Incorrect gear ratio (Buy Part On Amazon) | Wiring, TR sensor/switch, shift solenoids, transmission mechanical fault |
What Does Code P0730 Mean?
The TCM (transmission control module) calculates gear ratio based on data from the transmission input shaft speed (ISS) and output shaft speed (OSS) sensors. The TCM compares the calculated gear ratio to the known gear ratio for each commanded gear. If the TCM detects an incorrect 1st gear ratio while decelerating in LOW (L), indicating no engine braking within the transmission, then DTC P0730 sets. DTC P0730 is a type A DTC.
This DTC monitors actual gear position by checking the torque converter slip ratio calculated by Transmission Control Module (TCM) as follows:
Torque converter
A = Output shaft revolution signal from speed sensor (OSS/VSS)
B = Engine speed signal: CKP (Crankshaft Position) sensor from ECM/PCM
C = Gear ratio determined as gear position which TCM want it to be in
If the actual gear position is higher than the position supposed by TCM, the slip ratio will be more than normal. In case the ratio exceeds the specified value, TCM judges this diagnosis malfunction.
DTC P0730 TCM (transmission control module) has detected that the transmission is trying to mechanically shift to a lower gear than intended.
What are the common causes of code P0730 ?
- Dirty transmission fluid
- Shift solenoids
- Transmission mechanical problems
- Transmission hydraulic control circuit
What are the symptoms of code P0730 ?
- Transmission shifting problems
Mi auto solo da primera y segunda marcha, de 3ra en adelante se neutraliza y se prende en el tablero todos los foqiitos que indican la mercha en que está (prn4321) se reparo la transmision por desgaste en discos de pasta y desde entonces me sucede lo ya explicado y se coloca el código p0730, de antemano gracias.
My car (Toyota Chaser) is having harsh gear shifts especially from gear number 1 to gear number. What might be the cause and my car has an automatic transmition.
Mallon-
I would start by checking transmission fluid level.
