P0727 – Engine RPM input -no signal
Last Updated 2021-12-08
P0727 | Engine RPM input -no signal (Buy Part On Amazon) | Wiring, CKP/RPM sensor, ECM/PCM!TCM |
What Does Code P0727 Mean?
OBD II fault code P0727 is a generic code that is defined as, “Engine Speed Input Circuit No Signal”, and is set when the PCM (Powertrain Control Module) detects the absence of an input signal from the engine speed sensor.
NOTE: On some vehicles, the engine input sensor is also known as the “transmission input speed sensor”, and might be located on the transmission casing where it can interact with a reluctor wheel inside the transmission. On some other applications, such as many, if not all VW and related VAG-group vehicles, the crankshaft position sensor does double duty as the engine speed sensor when the engine is running.
The control system of a modern automatic transmission requires an enormous amount of input data from many different sources to manage gearshifts effectively, and an actual gearshift is the result of complex calculations that are based on a large variety and range of operating parameters.
In simple terms though, a transmission control system needs to know four things to function, these being the engine speed, the engine load, the currently selected gear, and the position of the throttle plate i.e. if the throttle is opening or closing.
These four parameters represent the absolute minimum in terms of input data any transmission control system requires to work. However, of these four parameters, the engine speed is arguably the most important (all other things being equal), since all shift points are based on the actual engine speed. For instance (and regardless of the selected operating mode), transmission control systems are programmed to initiate gearshifts at pre-defined engine speeds to a) prevent component damage, b) minimize exhaust emissions, and c) to maximize engine performance while using the least amount of fuel, at the same time.
Thus, accurate, valid, and plausible input data on the actual engine speed is a crucially important parameter to ensure efficient transmission control. Therefore, should a failure, defect, or malfunction in the input speed sensor or its associated electrical circuits occur that deprives the PCM or TCM (Transmission Control Module) of an input signal, these modules will recognize that they cannot control the transmission effectively.
Note that while such a failure or malfunction will usually cause code P0727 to set on the first failure, whether (or not) a warning light will also illuminate depends on the vehicle make and model. On some vehicles, a warning light will illuminate on the first failure, while on others, two or more failures need to occur on two consecutive trips before a warning light will illuminate.
Where is the P0727 sensor located?
This diagram shows the location of the engine speed input sensor on the transmission of a 2010 Jeep Grand Cherokee.
Note that both the appearance and location of engine speed input sensors vary so much between vehicle makes and models that it is not possible to include a representative example of such a sensor here. Therefore, we strongly recommend that you obtain professional assistance with the diagnosis and repair of suspected engine speed input sensor issues.
What are the common causes of code P0727 ?
The common causes of code P0727 are largely similar across all applications, and could include one or more of the following-
- Defective or malfunctioning engine speed input sensor
- Damaged, burnt, shorted, disconnected, or corroded wiring and/or electrical connectors
- In cases where the PCM and TCM are separate, damaged wiring and/or poor electrical connections between the two control modules can also cause this code to set
- Failed or failing PCM/TCM, but note that this is a rare event, and the fault must therefore be sought elsewhere before any control module is reprogrammed or replaced
What are the symptoms of code P0727 ?
Typical symptoms of code P0727 could include one or more of the following, but note that in some cases, there may be no symptoms present apart from a stored trouble code-
- Depending on the vehicle and the nature of the problem, multiple additional codes may be present along with P0727, with UXXXX (Communication) codes being the most common
- A no-start condition may be present on vehicles where the CKP (crankshaft position sensor) does double duty as the engine speed input sensor
- Fuel consumption may increase noticeably
- Gearshifts may be harsh, erratic, or unpredictable
- The transmission may be locked into one gear, or the transmission may not select some gears
- In some cases, the transmission may not select any gears
- The vehicle may stall unpredictably at low engine speeds
- The vehicle may be locked into a fail-safe or limp mode that will persist until the fault is corrected
Hi. Whom can let me know how it can be fixed the P0727 code for the mentioned model (Skoda octavia 1.9Tdi Axr engine tipe. Thanks.
Where is engine speed input and also rpm sensor in skoda Laura.pls give me reply
How can i get it fixed
Were is my engine speed input on a 2007 suzuki xl7 3.6 gm motor
