P0720 – Output shaft speed (OSS) sensor -circuit malfunction
Last Updated 2016-01-17
Ed.D, PhD Philosophy, BSME
P0720 | Output shaft speed (OSS) sensor -circuit malfunction (Buy Part On Amazon) | Wiring, VSS, ECM/PCM!TCM |
What Does Code P0720 Mean?
The TCM (transmission control module) or PCM (powertrain control module) has received an input signal from the transmission OSS (output speed sensor) or VSS (Vehicle speed sensor) that is erratic. Without a accurate output speed signal the transmission cannot properly shift the transmission or transaxle, so this code sets. Output speed sensors detect speed by using the revolution of the output gear which is also the parking pawl gear, which is used as a reluctor (valley) for either PM generator or a Hall-Effect sensor that creates a sine or square wave pulse signal. The pulse signal is sent to the control module (TCM or PCM) which processes it as the vehicle speed.
What are the common causes of code P0720 ?
- Defective OSS (Output Speed Sensor) or VSS (Vehicle Speed Sensor)
- Wiring from control module (TCM or PCM) is open or shorted
- Defective or corroded electrical connectors
What are the symptoms of code P0720 ?
- Speedometer problems not displaying the right vehicle speed
- Shifting problems, either rough or no upshift
- Poor fuel economy
- Stalling in rare cases
- ISS (input speed sensor) DTC P0715 may also set
Hola tengo una ford ranger automática 2014. Me esta fallando la transmisión automática y el scanner acusa P0720 y P0402. Dónde está ubicado el sensor de velocidad?
Tengo un mazda3 2008 tengo ese problema puedo cambiar el tcm o el censor de velocidad
Tengo una camioneta frontier me aparecio la luz en el tablero revisamos y me aparece el codigo Una respuesta a “P0720 – Sensor de velocidad del eje de salida (OSS) – mal funcionamiento del circuito” no se que es pero la camioneta estafuncionando correctamente hojala y me puedan ayudar.
i have range rover vouge 2007 super charged 4.2- having problem hen car goes from third gear to fourth gear it takes a jerk and come back in third gear-and its computer screen shows – transmission fault limited gears only- special programes off-
can anybody help in this matter what is going on and what should i do-
thanks
sun
