P0710 – Transmission fluid temperature (TFT) sensor circuit malfunction
Last Updated 2016-01-15
Ed.D, PhD Philosophy, BSME
P0710 | Transmission fluid temperature (TFT) sensor circuit malfunction (Buy Part On Amazon) | Wiring, TFT sensor, ECM, ECM/PCM!TCM |
What Does Code P0710 Mean?
The TFT (transmission fluid temperature) sensor is part of the automatic transmission fluid pressure (TFP) manual valve position switch and is a thermistor that changes value based on temperature. The TFT is an NTC (negative-temperature coefficient), which means that as the temperature increases, the resistance decreases, and as the temperature decreases, the resistance increases. The PCM (powertrain control module) supplies a 5-volt reference signal to the sensor and measures the voltage drop in the circuit. When the transmission fluid is cold, the sensor resistance is high and the PCM detects high signal voltage. As the fluid temperature warms to a normal operating temperature, the resistance becomes less and the signal voltage decreases. This sensor is used by the PCM or TCM to detect the temperature of the automatic transmission fluid. This signal is used to determine the best shift points and to regulate line pressure. It will cause the control module (PCM or TCM) to engage the TCC (torque converter clutch) sooner and disable overdrive, to help reduce the fluid temperature if it reaches higher than normal.
Figure 1 TFT Circuit Wiring Diagram
When the control module (PCM or TCM) detects one of the following unusual conditions, then DTC P0710 sets.
- Unrealistically large change in transmission temperature
- Transmission temperature which remains constant for a period of time in which a measurable amount of change is expected and is a type C DTC
What are the common causes of code P0710 ?
- Faulty Transmission Fluid Temperature Sensor
- Transmission Fluid Temperature Sensor harness is open or shorted
- Transmission Fluid Temperature Sensor circuit poor electrical connection
What are the symptoms of code P0710 ?
- Possible automatic transmission shifting problems
Hi
I have a Fault Code of PO710 on a 2010 Fiat Ducato Semi Automatic gearbox, the engine size is 3.0ltr diesel.
Could you please tell me where the Sensor is located?
