Skip to content
TroubleCodes.net By BAT Auto
"Once you eliminate the impossible, whatever remains, no matter how improbable, must be the truth." - Sherlock Holmes
  • All Codes
  • OBD Codes
  • About OBD2
  • Nonsense Codes
  • OBD2 Sensors
  • PXXXX
  • UXXXX
  • BXXXX
  • CXXXX
Posted on November 18, 2015 by BAT Team
P0645 – Air conditioning (AC)
BAT Team
Last Updated 2015-11-18
P0645 Air conditioning (AC) Wiring, AC system
BAT Team Discussions for P0645
None found. Ask a question about P0645.
0 0 vote
Article Rating
Subscribe
Login
Notify of
guest
Manufacturer
Model
Year
Miles
Engine
guest
This site uses Akismet to reduce spam. Learn how your comment data is processed.
7 Comments
oldest
newest most voted
Inline Feedbacks
View all comments
Pierre
Pierre
2 years ago
Liguei meu Ar Condicionado direto sem o módulo ( Fiesta 2009/2010 ), pois o relé estava mandando pouca corrente negativa e não gelava, passei 2 dias tudo ok, o Ar ótimo, agora parou de novo de gelar e apareceu o cód P0645, possível causa fiação. Oque fazer? Grato desde já.
Meu e-mail pra respostas.
[email protected]
0
Reply
Jason Wells
Jason Wells
1 year ago
Do I have a relay for the AC clutch and the front and in the back trunk fuse box if so what number please
Make:
Chrysler
Model:
300lx
Year:
2008
Miles:
140000
Engine:
2.7 v6
0
Reply
Benjamin Jerew
Editor
Benjamin Jerew
1 year ago
Reply to  Jason Wells
The AC clutch relay should be under the hood in the Integrated Power Module, AKA “Fuse Box,” right next to the horn relay. I read the Horn Relay and AC Clutch Relay are fed by the same fuse, so if the fuse blows, you lose Horn and AC. Also, the horn relay and AC relay are identical, so you should be able to swap-tronic them.
0
Reply
Jason Wells
Jason Wells
1 year ago
Reply to  Benjamin Jerew
I change all of them .. Still same.. If it hook meter up to plug that goes in to the ac clutch i get 10.7v dc and when i hit ac button in car it goes to 11.5.v Dc If in unplug it from ac clutch and i wire my own 12.v dc it comes on and cold and i check freon presser when ac clutch is engaged and it read normal on ac presser Freon.. Iam confused .. Is 11.5v not enough to kick it on. Please help.. Lol
0
Reply
Benjamin Jerew
Editor
Benjamin Jerew
1 year ago
This might be getting too complicated to diagnose over the internet, but I’m wondering if you might have a bad ground after the AC clutch. If you’re getting 11.5 V, it seems like 2 V are getting sucked up somewhere else. Double-check you have ≈13.5 V engine running AC clutch disconnected AC engaged, then check ground straps and other ground points for excessive resistance.
0
Reply
Jason Wells
Jason Wells
1 year ago
Took it to have it service.. they ran scan on it come to find out it is the pcm.. I ran a switch to the ac clutch so I manually turn it on until my com comes in.. thanks for your comments
0
Reply
Jeremy Noe
Jeremy Noe
1 year ago
Has anybody found the wiring issue to the a/c compressor
Make:
Ford
Model:
F250
Year:
2005
Miles:
298000
Engine:
6.0 diesel
0
Reply
Post navigation
Previous PostPrevious P0617 – Starter motor relay -circuit high
Next PostNext P0724 – Torque converter/brake switch B -circuit high
wpDiscuz
