P0605 – Engine control module (ECM) -ROM error
Last Updated 2016-07-08
P0605 | Engine control module (ECM) -ROM error | ECM |
What Does Code P0605 Mean?
P0605 is a generic OBD II powertrain code that applies to all makes and models of vehicles 1996 and newer. This code means that a control module read only memory error has been detected. The issue may be in the Power Control Module (PCM) or one of the other supporting control modules. Depending on the year, make and model of the vehicle it may incorporate several independent control modules. Some of the most common examples are the transmission control module, the body control module or fuel injection control module and the anti-lock brake control module. These modules are monitored by the PCM at all levels of vehicle operation and even at idle. The PCM translates these readings and makes adjustments to power inputs to control fuel pressure, shifting and anti-lock brake operation. OBD II error code P0605 indicates that the PCM has lost the ability to monitor one or more control modules. This means the ability to adjust the control module for the automobile to operate correctly has been disabled. Other control modules may be incorporated to support additional features such as a turbocharger, traction control and cruise control. As technology advances, driver-assist features increase and the list of control modules required continues to grow.
What are the common causes of code P0605 ?
A lot of P0605 error code issues are simple in nature such as a loose connection, defective wiring harness or a broken wire. Corrosion is also a huge issue when it comes to malfunctions associated to PCM and control module problems. Some control modules may be exposed to the elements causing corrosion issues. PCM’s are normally high and dry unless you have a heater core issue that is one of the reasons a PCM may need to be replaced. Ground issues are one of the main causes of power loss to PCM’s and control modules that must be grounded to operate. Loose ground straps are very common and are caused by road vibration. Some PCM’s and control modules are grounded through the case or cover. When the mounting bolts become damaged or loose these components are no longer grounded and the power input is disabled. PCM flashing is often required to reset the control module. Software upgrades are very common as well and are developed by the manufacture to correct known issues. Stored errors codes that are not cleared commonly cause a P0605 error code. Of course, sometimes PCM’s and control modules experience internal failure and must be replaced.
Common Misdiagnosis
Stored error codes can often lead to a misdiagnosis for the OBDII P0605 error code. You should use freeze frame data to determine which codes were stored first. Engine misfire codes, lean exhaust codes, fuel injector codes, and other drivability or transmission codes can also be present interfering with the troubleshooting process. You should diagnose codes in the order that they are stored. This will improve your chances for a successful diagnosis.
What are the symptoms of code P0605 ?
Check engine light on:
The ECM will detect the control module read only memory error and illuminate the check engine light. This is to alert you of the issue and prompt you to have the system scanned as soon as possible.
Decreased fuel economy:
Decreased fuel economy is common to all performance issues and the P0605 code is not an exception to that rule. In this situation, fuel consumption can be affected by multiple sources. The fuel pressure to the injectors or fuel to the throttle body may be at the wrong level. The transmission could be hanging in gear for too long burning more fuel. The list goes on and on.
Harsh shifting or transmission hesitation:
Harsh shifting or transmission hesitation will occur if the PCM or the transmission control module is not functioning properly. This situation can cause extensive damage to the transmission and requires immediate attention.
Poor Acceleration, rough idle or stalling:
This is an indication that the ability of the PCM or fuel control Module is be affected due to a defect or other associated components.
Anti-lock brake system not activating:
This situation verifies that the malfunction is affecting the anti-lock brake system. It could be a PCM or an anti-lock brake control module issue.
Optional features are not functioning properly:
If advanced features such as a turbo charger, the cruise control module or driver- assist features are not working. This all goes back to the PCM which is brain of the operation. The problem may be isolated to the specific system is some scenarios.
How do you troubleshoot code P0605 ?
The best starting point is the PCM:
Inspect for physical damage
Check power input
Inspect wiring and connections
Check tech bulletins for software updates
Flash the PCM if recommended
Make sure it is grounded
Check the control module for the system malfunctioning:
Check power input
Check function if it’s mechanical
Codes Related to P0605
P0600 – Serial Communication Link
P0601 – Internal Control Module Memory Check Sum Error
P0602 – Control Module Programming Error
P0603 – Internal Control Module Keep Alive Memory (KAM) Error
P0604 – Internal Control Module Random Access Memory (RAM) Error
P0605 – Internal Control Module Read Only Memory (ROM) Error
P0606 – ECM/PCM Processor
P0607 – Control Module Performance
P0608 – Control Module VSS Output ‘A’
P0609 – Control Module VSS Output ‘B’
P0610 – Control Module Vehicle Options Error
BAT Team Discussions for P0605
- 2001 doge caravan transmission problems can anyone help please???
Hello I got those codes using the key turn method. But I also went to Auto Zone and had the scanner put on my van and the code they got was P0605 meaning there was a failure with the ECM. I really want to know if the ECM and TCM are the same thing. When I went to Dodge dealership about my selenoi... - 2011 Nissan Maxima CAN lines
Is a P0605 present?...
2006’chrysler 300 3.5 liter. My not allow me to drive above 38 miles mph
. If I try to get pass 38 mph it stalls out. Scanning post P0605.
Hi James,
This situation most likely means the Power Control Module (PCM) is putting the vehicle in limp mode. Several malfunctions can cause this issue and it is very common with Chrysler cars and Dodge trucks. There may be a software upgrade for the computer available that could possibly help. Chrysler’s are also known for transmission speed sensor issues as well. I can’t say for sure, I can only point you in the right direction. Thanks for commenting on Troublecodes.net! Regards, John
I just recently was told I have a P0605 code on my 2001 Chrysler Town & Country. I have read through all the remaks and understand what it is. My question is, it sounds like potential “transmission” problems are just a part the issue with this code. My issue is that it gets to about 30 mph when it should be kicking into another gear (automatic) but the RPM’s start getting high. At 40 mph, it has about a 4000 RPM. I can also hear it making a high pitch sound. In one of your descriptions, it talks about getting the technician to do a “freeze frame” when getting this code to possibly determine another level of detail. Is this something I should ask the technician about in order to drill down to a solution better? I’ve been given an estimate of $650 to get it fixed.
No.
You are obviously brain-dead enough to think a simple internet search will answer all of your questions.
Sell the vehicle and buy a tricycle.
Then buy a plant to replace all of the oxygen you are wasting.
Hola tengo un error en la centralita de mi coche el error es p0605.
no encuentro ha nadie que me lo arreglen por eso me pongo en contacto con ustedes a ver si le diesen ayudar esta es mi referencia de la centralita 0281013366 .
Es un Renault gran scenic 1.9 131cv. 96kw .
Gracias
Este tipo de fallas DTC, son códigos fijos duros y rastreables, nada fácil, solo que los clientes quieren que se los platiquen como si fuera un cuento, eso no es ético, hay muchas pruebas que hacer y confirmar la veracidad de señales de comunicación asta llegar a una re-programación general, el cliente se debe poner como lo es, solo cliente y esta pidiendo prestación de servicio y por tal debe pagar, si le cuentan que estaba cortado o quemado un alambrito y se restauro el daño, le cobran por decir $ 1500.00, y el cliente reclama, por que abusa, por que tan caro si solo pego un alambrito y le puso cinta y ya, por que no lo hizo el cliente, SEÑORES CLIENTES, HAY MECÁNICOS ELÉCTRICOS Y TRANSMISIONEROS QUE ESTUDIAMOS Y NOS DESVELAMOS CON SUS FALLAS Y ASTA PERDEMOS LA SALUD, PAGUEN POR TAL HECHO, ES JUSTO.
