P0569 – Cruise control selector switch, COAST signal malfunction
| P0569 | Cruise control selector switch, COAST signal malfunction (Buy Part On Amazon) | Wiring, cruise control selector switch, ECM |
Reading P0569 on your car
A basic adapter will show you P0569, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
We have not gotten around to publishing a technical guide specifically for P0569 – Cruise control selector switch, COAST signal malfunction yet.
