P0568 – Cruise control master switch, SET signal -malfunction
| P0568 | Cruise control master switch, SET signal -malfunction (Buy Part On Amazon) | Wiring, cruise control master switch, ECM |
Reading P0568 on your car
A basic adapter will show you P0568, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
We have not gotten around to publishing a technical guide specifically for P0568 – Cruise control master switch, SET signal -malfunction yet.
