P0564 – Cruise control system, multi -function switch input A -circuit malfunction
| P0564 | Cruise control system, multi -function switch input A -circuit malfunction (Buy Part On Amazon) | Wiring, poor connection, multi -function switch, mechanical fault |
Reading P0564 on your car
A basic adapter will show you P0564, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
We have not gotten around to publishing a technical guide specifically for P0564 – Cruise control system, multi -function switch input A -circuit malfunction yet.
