P0547 – Exhaust gas temperature sensor, bank 2 sensor 1 circuit malfunction
| P0547 | Exhaust gas temperature sensor, bank 2 sensor 1 circuit malfunction (Buy Part On Amazon) | Wiring, poor connection, exhaust gas temperature sensor, ECM |
Reading P0547 on your car
A basic adapter will show you P0547, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
We have not gotten around to publishing a technical guide specifically for P0547 – Exhaust gas temperature sensor, bank 2 sensor 1 circuit malfunction yet.
