P0544 – Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 1
P0544 | Exhaust gas recirculation temperature (EGRT) sensor, bank 1 -circuit malfunction (Buy Part On Amazon) | Wiring, EGRT sensor, ECM |
- What Does Code P0544 Mean?
- Where is the P0544 sensor located?
- What are the common causes of code P0544 ?
- How expensive is it to fix code P0544 ?
- What are the symptoms of code P0544 ?
- Get Help with P0544
P0544 is a generic code trouble code defined as Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 1. This code is triggered when the PCM (Powertrain Control Module) fails to receive a plausible signal from the sensor that measures the temperature of exhaust gasses.
Exhaust gas temperature is one of the running parameters that PCM in modern cars monitors at all times. There are several reasons for this, with the first having to do with the catalytic converter. For it to work, the exhaust gas temperature has to be high enough. Otherwise, the catalytic process will not be efficient enough. But if the gases become too hot, they could damage and melt the honeycomb mesh within the converter. In addition, exhaust gas temperature is a crucial parameter in turbocharged engines, which may get damaged if it becomes too hot.
The PCM can try to bring the exhaust gas temperature within acceptable limits by adjusting fuel injection or timing. Or, in the case of turbocharged engines, it will lower the boost. But to do so, it has to know the exhaust gas temperature, and that’s what the EGT sensor is for.
Lastly, modern cars and trucks with Diesel engines have a DPF filter. This is short for Diesel Particle Filter, a device installed within the exhaust to catch soot and other particles. With time, the DPF filter gets filled up, which is when the PCM will start the regeneration process. It does this by adding more fuel during the combustion, which increases the exhaust gas temperature and burns off particles accumulated inside the filter. But to decide when the DPF filter needs to be regenerated, the PCM has to know the exhaust gas temperature before and after it. This is why vehicles with DPF filters have two EGT sensors, one upstream of the filter and the other downstream of it.
The EGT sensor measures the exhaust gas temperature, which dictates its location. So, it will be fitted to the exhaust pipe, between the manifold and the catalytic converter, regardless of the make or model. In cars with Diesel engines, this sensor will be upstream of the DPF filter. These vehicles will usually have two EGT sensors, with the other one being fitted just behind the filter.
But V6 and V8 engines, however, can be tricky, as they have two EGT sensors, one for each bank. The P544 error code refers to bank 1, whose location depends on the engine and drivetrain layout. In most cars, if the engine is mounted sideways, bank 1 will be the one facing the firewall. Rear-wheel-drive cars, however, have their engines fitted lengthways. Here, bank 1 on most cars will be on the right-hand (passenger) side of the car. But have in mind this may differ depending on the manufacturer.
For reference, here is how this may look in a Mercedes-Benz, which has three EGT sensors. One is just behind the turbocharger. and the remaining two are before and after the DPF filter.
The working principle behind the EGT sensor is similar to those of most sensors used on a modern-day vehicle. The PCM sends a 5-voltage current to the sensor and then measures the voltage it gives back. The resistance within the sensor changes as the exhaust gas temperatures go up and down, which affects the voltage. Some of the most common failure points include:
- damaged or broken wiring that leads to the EGT sensor
- loose or corroded EGT sensor connector
- soot buildups on the EGT sensor, which offset its readings
- short-circuited EGT sensor
- an aftermarket exhaust system without a catalytic converter or DPF filter
- large air leak between the exhaust manifold and the EGT sensor
How much it costs to repair the P0544 code differs depending on what’s causing it, as well as the vehicle itself. The EGT sensor, if it needs to be replaced, is usually not expensive. For most popular vehicles, the prices of aftermarket replacement sensors are $50 or less. And as always, OEM parts bought from the authorized dealer might be noticeably more expensive.
Apart from the price of the EGT sensor itself, there is also a cost of labor if it is replaced by a professional mechanic. But for most vehicles, this is a relatively simple job that will not more than an hour.
Symptoms the driver may notice when the P0544 code is set differs depending on the make and model. This includes the following:
- an illuminated Check Engine Light on the dashboard – all cars
- increased fuel consumption – in Diesel-powered vehicles with DPF filters, if the regeneration process is triggered more often
- reduced boost pressure – in turbo-charged cars, triggered by the PCM as a precaution
P0544 este senzorul G235 ?
Egr
