P0516 – Battery temperature sensor -circuit low
| P0516 | Battery temperature sensor -circuit low (Buy Part On Amazon) | Wiring short to earth, battery temperature sensor, ECM |
Reading P0516 on your car
A basic adapter will show you P0516, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
We have not gotten around to publishing a technical guide specifically for P0516 – Battery temperature sensor -circuit low yet.
