P0509 – Idle air control (IAC) -circuit high
| P0509 | Idle air control (IAC) -circuit high (Buy Part On Amazon) | Wiring short to positive, IAC valve, ECM |
Reading P0509 on your car
A basic adapter will show you P0509, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
We have not gotten around to publishing a technical guide specifically for P0509 – Idle air control (IAC) -circuit high yet.
