P0465 – Evaporative emission (EVAP) canister purge flow sensor circuit malfunction
| P0465 | Evaporative emission (EVAP) canister purge flow sensor circuit malfunction (Buy Part On Amazon) | Wiring, EVAP canister purge flow sensor, ECM |
Reading P0465 on your car
A basic adapter will show you P0465, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
We have not gotten around to publishing a technical guide specifically for P0465 – Evaporative emission (EVAP) canister purge flow sensor circuit malfunction yet.
