P0431 – Warm up catalytic converter, bank 2 -efficiency below threshold
Last Updated 2016-10-19
P0431 | Warm up catalytic converter, bank 2 -efficiency below threshold | Catalytic converter, wiring, HO2S 2 |
What Does Code P0431 Mean?
If you are reading this, I assume that your OBD-II equipped vehicle has stored a code P0431. This means that the powertrain control module (PCM) has detected a problem with the efficiency of the catalytic converter warm up function for engine bank two. Bank 2 indicates that the malfunction has occurred in the bank of the engine that does not contain the number one cylinder.
The catalytic converter is used to reduce exhaust emissions from diesel and gasoline fueled engines. It is constructed using a filtration element of ceramic and precious metals enclosed in a steel housing and placed in the exhaust pipe. Harmful nitrogen oxides (N2O), carbon monoxide, and unburned hydrocarbons are all converted to harmless ions of nitrogen, oxygen, carbon dioxide, and water inside the catalytic converter. This is accomplished using the dense web of filtration and the extreme heat of the engine exhaust. Catalytic converter temperatures must reach at least 800-degrees Fahrenheit.
Catalytic converter efficiency is monitored using upstream and downstream oxygen (O2) sensors. The O2 sensors are zirconium dioxide sensing elements enclosed in vented steel housings, connected to wire leads in the O2 sensor wiring harnesses by platinum electrodes. O2 sensor wiring harnesses are connected to the PCM via the controller area network. The O2 sensors provide the PCM with data regarding the percentage of oxygen particles in the engine exhaust as compared to the oxygen content of the ambient air.
Spent engine exhaust gases are pushed through the exhaust manifold, into the exhaust pipe, over the upstream O2 sensor, through the catalytic converter, and they pass over the downstream O2 sensor. Exhaust gases flow through vent holes in the steel housing and across the sensing element of the O2 sensors as outside air is drawn into a chamber in the middle of the sensors through the wire lead cavities.
Inside the chambers, the air is heated, forcing the oxygen ions to produce (energy) voltage. Deviations between the concentration of oxygen molecules in ambient air (drawn into the O2 sensor) and the concentration of oxygen ions in the exhaust cause voltage fluctuations. These deviations cause the oxygen ions inside the O2 sensor to bounce from one platinum layer to the other, very rapidly and repetitiously. Fluctuations in voltage occur as the surging oxygen ions bounce between platinum layers. The PCM identifies these changes in voltage as variations in exhaust oxygen concentration. These variations signify whether the engine is running lean (too little fuel) or rich (too much fuel). When the signal output from the O2 sensor is lower, more oxygen is present in the exhaust (lean condition). If the voltage signal output is higher, less oxygen is present in the exhaust (rich condition). This data is used by the PCM to compute fuel delivery strategy and ignition timing, as well as other things.
If the upstream and downstream O2 sensors reflect a similar exhaust oxygen concentration, a code P0431 will be stored and a malfunction indicator lamp may be illuminated.
What are the common causes of code P0431 ?
- Faulty catalytic converter
- A faulty mass air flow or manifold air pressure sensor
- Defective O2 sensor/s
- Burnt, chafed, broken, or disconnected wiring and/or connectors
- Engine exhaust leak
What are the symptoms of code P0431 ?
- Diminished fuel efficiency
- A lack of general engine performance
- Other related diagnostic trouble codes may also be stored
- Service engine soon lamp illumination
How do you troubleshoot code P0431 ?
A diagnostic scanner, digital volt ohmmeter (DVOM), and a reliable vehicle information source (such as All Data DIY) will prove necessary when diagnosing a code P0431.
Misfire codes, throttle position sensor codes, manifold air pressure codes, and mass air flow sensor codes should be addressed before attempting to diagnose a stored code P0431. The engine should be running efficiently before diagnosing this code.
With a P0431, I would begin with a visual inspection of system wiring harnesses and connectors. Meticulously inspect harnesses that are routed near hot exhaust pipes and manifolds, as well as those that are routed near sharp edges like the ones found on exhaust shields.
Proceed by connecting the scanner to the vehicle diagnostic port and retrieving all trouble codes and freeze frame data. Write this information down because it may be helpful if this proves to be an intermittent code. Intermittent codes can be much harder to diagnose. Now, clear the codes and test drive the vehicle.
If the P0431 is immediately reset, start the engine and allow it to reach normal operating temperature, then allow it to idle (with the transmission in neutral or park). Use the scanner data stream to observe O2 sensor input data. Narrowing the data stream to include only pertinent data will yield faster data response. If the engine is running efficiently, the upstream O2 sensor will cycle regularly from one-millivolt (.100-volts) to nine-millivolts (.900-volts) and downstream O2 sensor data should reach a mid-line and settle there. If upstream and downstream O2 sensor readings are too similar, after the PCM has reached closed loop operation, suspect a defective catalytic converter.
Use the DVOM to check resistance of the O2 sensor/s in question, as well as voltage and ground signals for O2 sensor circuits. Use caution and disconnect related controllers before attempting to test system circuit resistance with the DVOM.
Codes Related to P0431
- P0430 Catalyst System Efficiency Below Threshold (Bank 2)
- P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
- P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
- P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
BAT Team Discussions for P0431
- Dodge Intrepid code
We need mileage and engine and year. Any other codes ? What is repair and tune up history? If it is the cat bad they are under federal warranty for 80k or 8 years. But one of the main causes of cat codes is bad tune up or engine miss or running rich. Also sometimes there is a pcm reflash for the pro... - 99 Suburban 5.7 OBDII code P0430
Code does not say replace or the cat or o2 sensors are bad. How is the tune up. Engine miss or runing rich is the leading cause of cat code? http://www.troublecodes.net/articles/catfailure/ A little info on cat codes. :) DTC P0420, P0421, and P0430 & P0431: Check Possible Cause Of Misfire DTC P... - PO430- 98 Explorrer 4.0L SOHC 2WD
[quote="ScottVA"] My wife was driving my truck and was on some ice and someone pushed her into a pole. She hit the pole on the drivers' side from the front of the wheel well flare to the gas filler door. She didn't hit very hard- mostly scs along the quarter panel. Anyway, after this incident, the C... - 01 Pontiac Sunfire P0420
Engine running rich or not right or missfire is the main cause of cat codes. And sometimes 02 sensors. http://www.troublecodes.net/articles/catfailure/ A little more info. :) DTC P0420, P0421, and P0430 & P0431: Check Possible Cause Of Misfire DTC P0420 and P0421 indicate bank one catalyst syste... - 1998 Dodge grand Caravan trouble codes
One of the main causres of cat codes is bad tune up missfires anfd rich exhaust. How many miles on you last tune up? Kev-2 posted a good link. Here is a little to add to it. :) DTC P0420, P0421, and P0430 & P0431: Check Possible Cause Of Misfire DTC P0420 and P0421 indicate bank one catalyst syste...
Leave a Reply
