P0406 – Exhaust gas recirculation (EGR) valve position sensor A high input
| P0406 | Exhaust gas recirculation (EGR) valve position sensor A high input (Buy Part On Amazon) | Wiring short to positive, EGR valve position sensor, ECM |
- What Does Code P0406 Mean?
- What are the common causes of code P0406 ?
- What are the symptoms of code P0406 ?
- How do you troubleshoot code P0406 ?
- Codes Related to P0406
- Get Help with P0406
In the internal combustion engine, the ideal chemical reaction of combustion is as follows: oxygen (O2) + fuel (HC) = carbon dioxide (CO2) + water (H2O). Unfortunately, because engines are used over such a wide range of situations, ideal combustion often difficult to achieve. Outside of the lab, for example, there is a wide range of ambient temperature and humidity conditions, atmospheric pressure changes, as well as differing driver demands and even the state of the engine itself, all of which can lead to less-than-ideal combustion. Modern engines employ a number of strategies to achieve ideal combustion in ever-changing circumstances, using systems like variable valve timing and lift, variable ignition timing, direct fuel injection, and exhaust gas recirculation (EGR), to name a few.
The EGR system is designed to reduce the production of nitrogen oxides (NOx), which are responsible for the formation of smog and acid rain (Nitric Acid – HNO3), amongst other environmental and health hazards. Under ideal conditions, nitrogen (N2) would normally not react with the oxygen during combustion, but abnormally-high combustion temperatures, typically over 2,400 °F, can enable N2 reactions and the formation of NOx. The EGR system injects a small amount of spent exhaust gases, routed from the exhaust pipe, back into the intake, reducing the amount of O2 available for combustion, therefore reducing combustion temperatures and the production of NOx.
The EGR system connects the exhaust to the intake via pipes and a valve. The EGR valve used to be vacuum-modulated, but many vehicles have switched over to electronic control by the engine control module (ECM). Depending on demand, the ECM commands the EGR to open and close, controlling the flow of exhaust gas into the intake. The ECM also uses sensors to monitor system function, such as the EGR Temperature or Flow Sensor and EGR Position sensor. If the ECM detects a problem in the EGR position sensor circuit, it will set a diagnostic trouble code (DTC) and illuminate the malfunction indicator lamp (MIL).
Depending on year, make, and model, DTC P0406 may have number of causes. Here are some of the most common.
- Sensor Fault – Because it is constantly subjected to heat from the exhaust, internal electrical faults are a common occurrence. Replace the sensor, clear the code, keep driving.
- Circuit Problem – Certain repair procedures may require disconnecting the EGR position sensor or interfering with its harness. Poor connections, poor routing, chafing, open and short circuits are par for the course. Repair as needed.
- Dodge / Chrysler / Jeep / RAM / MOPAR – A number of models in this lineup have released TSBs (technical service bulletins) addressing DTC P0405 / P0406. Reprogramming the ECM fixes the problem. Check with your dealership to see if your vehicle is covered by any of these TSBs.
Aside from the MIL, you will most likely not notice any drivability problems associated with this particular EGR DTC. Still, because the ECM is now running in “limp-home mode,” you may notice a slight drop in performance and fuel economy.
Because this DTC describes a circuit problem, you’ll need a vehicle-specific EWD (electrical wiring diagram) and a DMM (digital multimeter) to diagnose it.
- General Check – Check the wire harness for obvious damage, such as from chafing or burns, which may cause circuit problems. Also, check for bent or broken pins, corrosion, or evidence of water entry. Repair as necessary and make sure connectors are properly seated.
- EGR Position Sensor Check – Most EGR position sensors are the three-pin type: reference voltage (Vref), Ground, and Signal. In the case of our Toyota EWD, these are VC, E2, and EGLS, respectively.
- If the EGR valve is vacuum-actuated, you can bench-test the position sensor with a DMM and vacuum-pump. Disconnect the connector and measure across the entire circuit (VC-E2), and you should measure something like 6 kΩ (6,000 Ω). On the signal wire, measuring between VC and EGLS, you should measure somewhere between 0.1 kΩ and 5.5 kΩ (100 Ω and 5,500 Ω), depending on how much vacuum you apply to the actuator port.
- If the EGR is electronically-actuated or you want to check output voltages, backprobe the connector with you DMM and measure voltage with KOEO (key on engine off). VC should measure somewhere between 4.5 V and 5.5 V and E2 should measure 0 V. ELGS should measure somewhere between 0.3 V and 4.2 V, which may vary, depending on the valve’s actual position. You can test voltage output of vacuum-operated valves by varying how much vacuum you apply with the hand pump.
- If you measure 5 V on E2, you most likely also measure 5 V on EGLS, which means you have an open circuit back to the ECM on the E2 ground circuit. Skip to Circuit Check to diagnose and repair.
- If you measure 5 V on VC and EGLS, but 0 V on E2, you may have an internal or external short circuit. Disconnect the sensor and check for resistance between VC and EGLS on the sensor itself.
- If you show less than 100 Ω, then you have a short circuited sensor. Replace it.
- If you show between 100 Ω and 5,500 Ω, you may have a short circuit in the wire harness. Skip to Circuit Check to verify and repair.
- If you measure 0 V on E2 and over 4.5 V on EGLS, then you have a fault in the sensor itself. Replace the sensor.
- Circuit Check – Disconnect the ECM and EGR position sensor and measure resistance on the three wires. Each wire, VC, EGLS, and E2, should measure 0 Ω end to end. Additionally, there should be no connection between any of the three wires or to ground. You should measure at least 10 kΩ between VC, EGLS, E2, and body ground. Repair as necessary.
- P0403 Exhaust Gas Recirculation (EGR) Control Circuit
- P0404 Exhaust Gas Recirculation (EGR) Control Circuit Range/Performance
- P0405 Exhaust Gas Recirculation (EGR) Sensor “A” Circuit Low
- P0406 Exhaust Gas Recirculation (EGR) Sensor “A” Circuit High
- P0407 Exhaust Gas Recirculation (EGR) Sensor “B” Circuit Low
- P0408 Exhaust Gas Recirculation (EGR) Sensor “B” Circuit High
- P0409 Exhaust Gas Recirculation (EGR) Sensor “A” Circuit
- P0486 Exhaust Gas Recirculation (EGR) Sensor “B” Circuit
- P0489 Exhaust Gas Recirculation (EGR) Control Circuit Low
- P0490 Exhaust Gas Recirculation (EGR) Control Circuit High
Reading P0406 on your car
A basic adapter will show you P0406, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
2007 Ford Mustang
Code read P0406 & I bought a EGR valve & put it in. reset computer but engine light still on.
went to have code read again gave same code + P0108?
What should I do to repair this???
Need help ASAP
Thanks
Unhook positive battery terminal for a few minutes. Reconnect and restart. Should clear
ENGINE PROTECTION, i have 406 and 404 error after and post egr valve sobstitution. I have clean fap, and gas recirculation circuit. Why i have error and protection again? How come control all sensor and circuit from – to the bosh control unit ECU?
Mazda 3 del 2004 1.6 TDI. Dopo aver sostituito la valvola EGR con una valvola aftmarket mi risulta un errore 406 alto provo a resettare l’errore ma una volta cancellato l’errore riappare.
fault code po406 on hyundai Tiburon 2l 1999. How easy is it to repair replace the EGR SENSOR
Mike-
As far as I know, the EGR position sensor is integrated into the EGR valve. It’s not a serviceable part, so you’ll have to replace the whole valve assembly. The only difficulty here is that, because the EGR valve is constantly subjected to exhaust heat, the fittings may be stuck. Plenty of WD-40 and perhaps the application of heat and patience will go far to removing the EGR valve without any collateral damage. You can use a touch of anti-seize lubricant on the threads of the fitting when you install the new EGR valve.
