P0404 – Exhaust gas recirculation (EGR) system range/performance problem
Last Updated 2016-07-08
P0404 | Exhaust gas recirculation (EGR) system range/performance problem | Hose leak/blockage, wiring, EGR valve/solenoid |
What Does Code P0404 Mean?
P0404 is a generic OBD II fault code that indicates that there is an issue with the Exhaust Gas Recirculation (EGR) circuit. The Engine Control Module (ECM) has detected that the EGR circuit is either out of range or not functioning properly. The purpose of the EGR system is to burn fuel more efficiently. The exhaust gases are routed back to the intake for combustion again. This process lowers emissions and increases fuel economy. There are several symptoms that identify an Exhaust Gas Recirculation problem.
What are the common causes of code P0404 ?
Carbon buildup:
Carbon buildup is the most common problem, when it comes to Exhaust Gas Recirculation Circuit issues. Proper air flow is essential for the system to function properly and carbon blocking tubes and hoses prevents this process. The exhaust gases must have a clear path to be routed back to the intake for combustion. This process regulates the amount of emissions that an engine ex-spells. In most cases, this problem can be eliminated by thoroughly cleaning of the components that are affected.
No vacuum pressure:
Vacuum pressure is required to operate a vacuum controlled EGR valve and it can be interrupted in several different scenarios. It may be as simple as a defective vacuum line, a broken slice or a broken tee. Vacuum pressure may also be affected by other associated components within the vacuum system.
No power:
The power to control an EGR valve can also be interrupted in several different ways and some may be difficult to pinpoint. It can be as simple as a loose connector that just needs to be secured properly. A basic wiring repair can also resolve some issues. Depending on the year, make and model of the automobile other situations can occur that are much more complicated. Fusible links are very common in newer vehicles and are often the source of electrical malfunctions.
Defective EGR valve gasket:
A defective EGR valve gasket can create multiple problems within the Exhaust Gas Recirculation system. This condition can affect or damage other associated components. Exhaust gases can escape and accumulate within the engine compartment and create a safety concern.
Defective tubes or hoses:
Defective tubes and hoses are a another very common issue due to wear and tear over time. These components must be in serviceable condition to properly route the exhaust gas from the exhaust manifold back to the intake.
The EGR valve is stuck open:
If the EGR valve is stuck in the open position then all of the exhaust gases will be directed to the intake. This situation causes the engine to run rough, possibly stall, and you will normally smell fuel. A stuck valve can sometimes be cleaned to correct the issue, but replacement is also occasionally required.
The EGR valve is stuck close:
When an EGR valve is stuck in the close position, it is most likely caused by carbon buildup. This situation blocks all exhaust gases and the engine performance will be noticeably affected in a negative manner. Same as the valve sticking in the open position, a closed valve can sometimes be cleaned to fix the problem, but replacement is also occasionally required.
What are the symptoms of code P0404 ?
Check engine light on:
The ECM will detect the improper range of the Exhaust Gas circulation system and illuminate the check engine light. This is to alert you of the issue and prompt you to have the system scanned as soon as possible.
Engine hesitation:
Engine hesitate is common to this defect and can be caused by several different situations. Some possibilities include a stuck EGR valve, defective hoses or carbon buildup.
Rough Idle:
EGR problems are known to cause a rough idle and this situation will be most noticeable when the engine is cold.
Engine Stalls:
Similar to the rough idle situation, the engine may stall when stopped and a red light or when attempting to proceed.
Increased fuel consumption:
Increased fuel consumption is another warning sign that will often occur when a EGR system malfunction exists.
Exhaust or fuel fumes:
Exhaust fumes are normally associated to a EGR valve that may be stuck in the closed position. Fuel fumes are an indication that the EGR valve could possibly be stuck in the open position.
Smoke coming out the tailpipe:
Smoke coming from the tailpipe is a huge indicator that a vehicle is experiencing EGR or emission problems.
Different types of EGR valves
Exhaust Gas Recirculation systems can have several different configurations and various types of EGR valves. Most valves are either vacuum or electrically operated based on the year, make and model of the vehicle. The type of EGR valve determines the correct troubleshooting approach that is required.
How do you troubleshoot code P0404 ?
Vacuum operated EGR valves:
Perform a visual inspection to determine the condition of the vacuum lines, tubes or hoses.
With the engine running, remove the vacuum line and verify that vacuum pressure is being applied.
With the engine running, check for exhaust leaks where the EGR valve mounts to the manifold, where tubes are connected and where hoses are connected.
Remove the tubes, hoses and the EGR valve to verify if there is carbon buildup causing the components to malfunction.
Inspect the EGR valve to verify that all of its components move freely and that it will completely open and close.
Electronically operated EGR valves:
Perform a visual inspection to determine the condition of the electrical connection, tubes or hoses.
With the ignition switch on, verify that the EGR valve is receiving a power input. ( normally about 5 volts for most vehicles)
Codes Related to P0404
P0401 – Exhaust EGR Flow Insufficient
P0403 – Exhaust Gas Recirculation Circuit Malfunction
P0405 – Exhaust Gas Recirculation Sensor Circuit A Low
P0406 – Exhaust Gas Recirculation Sensor “A” Circuit High
BAT Team Discussions for P0404
- 2003 Buick Century w/3.1; Timing Adjust Project
[b]Re: 2003 Buick Century w/3.1; OBD P0404 Code[/b] Guys, My Buick check engine light came on yesterday. I check the code and the only one logged was P0404. The vehicle has 149000 miles on it. I don't want to just hang a EGR valve on it without verifying that is the problem. How else shoul... - trouble code for 2005 crysler town & country
I need help on a code it is P0404 Exhust Gas Recirculation Circuit Range Performance. Thats what it reads. Does anyone know what that means and what do I do from this point to fix it. Our van has only 68k on it I hope its nothing major. Please help! Richard... - 98 cavalier code P0404
I'm working on a 98 chevy cavalier with a 2.2 liter engine, automatic, and has 2 codes that have to be cleared before it can be inspected. P0404 and P0405. The one says it is an exhaust gas recirculating control range. I took off the snorkel from the air cleaner to the throttle body and removed t... - poor running
02 olds alero 3.4 70000 miles. started running bad pulled codes had p0404 egr valve. replaced egr valve and replaced fuel filter didnt help. checked fuel pressure has about 50 pounds . car wont rev. over 2800 rmps it bogs down. dont pull hills good. transmission dont seam to shift right when you pr... - Jerking top kick diesel
[QUOTE="kev2, post: 100474, member: 35"]did you scan ?[/QUOTE] I do not have a [QUOTE="kev2, post: 100474, member: 35"]did you scan ?[/QUOTE] p0401, p0404, p0405, p1404...
If you have to change the egr valve or clean it there is a problem causing this and there can be many not listed over fueling by th injectors can cause this you need to get the vehicle on ford ids first to look at the injector fueling
the look towards the egr valve replacement. Garage mechanic
