P0394 – Camshaft position (CMP) sensor B, bank 2 -circuit intermittent
Last Updated 2016-08-22
P0394 | Camshaft position (CMP) sensor B, bank 2circuit intermittent (Buy Part On Amazon) | Wiring, poor connection, ECM |
What Does Code P0394 Mean?
If a code P0394 accompanies a malfunction indicator lamp (MIL) in your vehicle, it means that the powertrain control module (PCM) has detected a problem with the exhaust camshaft position sensor (or circuit) for engine bank one. Bank 2 represents the bank of the engine that does not contain the number one cylinder. Sensor B indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the exhaust camshaft.
When the engine is running, the PCM constantly compares input signals from the camshafts and the crankshaft. If the camshaft position is not within a specified degree of variation from the crankshaft and other camshafts, under certain circumstances, for a set period of time, a P0394 code will be stored and a MIL may be illuminated.
What are the common causes of code P0394?
What are the symptoms of code P0394?
- Diminished fuel efficiency
How do you troubleshoot code P0394?
Regardless of the code and the system affected, the word “Intermittent” refers to the fact that there is a sporadic, unpredictable, or, well, intermittent fault in that system. The most likely causes of codes that relate to intermittent faults include poor connections in both live and ground circuits, as well defective switches, relays, and sensors.
Before attempting to diagnose a code P0394, I would need a suitable diagnostic scanner, a digital volt/ohmmeter (DVOM), possibly an oscilloscope, and access to All Data DIY.
I like to perform a visual inspection of all system related wiring harnesses and connectors before beginning any testing. Wiring circuits, electrical sensors, and/or connectors that have been contaminated with engine oil, coolant, or power steering fluid should be examined carefully for damage. Petroleum based fluids may break down the protective insulation on wiring and lead to shorted or open circuits and a stored P0394. This is also a great time to load test the battery, check battery terminal ends and cables, and alternator output.
Codes Related to P0394
