P0393 – Camshaft position (CMP) sensor B, bank 2 circuit high input
Last Updated 2016-08-22
P0393 | Camshaft position (CMP) sensor B, bank 2 circuit high input (Buy Part On Amazon) | Wiring short to positive, CMP sensor, ECM - - - -· |
What Does Code P0393 Mean?
If a code P0393 accompanies a malfunction indicator lamp (MIL) in your vehicle, it means that the powertrain control module (PCM) has detected a problem with the exhaust camshaft position sensor (or circuit) for engine bank one. Bank 2 represents the bank of the engine that does not contain the number one cylinder. Sensor B indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the exhaust camshaft.
When the engine is running, the PCM constantly compares input signals from the camshafts and the crankshaft. If the camshaft position is not within a specified degree of variation from the crankshaft and other camshafts, under certain circumstances, for a set period of time, a P0393 code will be stored and a MIL may be illuminated.
What are the common causes of code P0393 ?
What are the symptoms of code P0393 ?
- Diminished fuel efficiency
How do you troubleshoot code P0393 ?
Circuit High Input codes are mostly caused by defective alternators that develop excessive voltages, although there may be other causes as well, such as short circuits that “leak” current into a particular system from other, unrelated systems that work on higher voltages. Note that in the case of short circuits that leak power into a control circuit, there is likely to be other, seemingly unrelated trouble codes present along with the code(s) being investigated. Diagnosing a “high input” code will always involve a thorough testing of the charging system as a first step, followed by measures to isolate the system from all other possible sources of power during resistance, continuity, and reference voltage tests.
Before attempting to diagnose a code P0393, I would need a suitable diagnostic scanner, a digital volt/ohmmeter (DVOM), possibly an oscilloscope, and access to All Data DIY.
I like to perform a visual inspection of all system related wiring harnesses and connectors before beginning any testing. Wiring circuits, electrical sensors, and/or connectors that have been contaminated with engine oil, coolant, or power steering fluid should be examined carefully for damage. Petroleum based fluids may break down the protective insulation on wiring and lead to shorted or open circuits and a stored P0393. This is also a great time to load test the battery, check battery terminal ends and cables, and alternator output.
Codes Related to P0393
I am also getting a p390 code with the p393. The 390 code will erase with the scanner,but the 393 does not. Cam sensor was replaced and the battery is new. The car is a 2006 IS250. Wanted to know if this codes together mean anything specific? Thank you
