P0392 – Camshaft position (CMP) sensor B, bank 2 circuit low input
Last Updated 2016-08-22
P0392 | Camshaft position (CMP) sensor B, bank 2 circuit low input (Buy Part On Amazon) | Wiring short to earth, CMP sensor, ECM - |
What Does Code P0392 Mean?
If a code P0392 accompanies a malfunction indicator lamp (MIL) in your vehicle, it means that the powertrain control module (PCM) has detected a problem with the exhaust camshaft position sensor (or circuit) for engine bank one. Bank 2 represents the bank of the engine that does not contain the number one cylinder. Sensor B indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the exhaust camshaft.
When the engine is running, the PCM constantly compares input signals from the camshafts and the crankshaft. If the camshaft position is not within a specified degree of variation from the crankshaft and other camshafts, under certain circumstances, for a set period of time, a P0392 code will be stored and a MIL may be illuminated.
What are the common causes of code P0392 ?
What are the symptoms of code P0392 ?
- Diminished fuel efficiency
How do you troubleshoot code P0392 ?
Before attempting to diagnose a code P0392, I would need a suitable diagnostic scanner, a digital volt/ohmmeter (DVOM), possibly an oscilloscope, and access to All Data DIY.
I like to perform a visual inspection of all system related wiring harnesses and connectors before beginning any testing. Wiring circuits, electrical sensors, and/or connectors that have been contaminated with engine oil, coolant, or power steering fluid should be examined carefully for damage. Petroleum based fluids may break down the protective insulation on wiring and lead to shorted or open circuits and a stored P0392. This is also a great time to load test the battery, check battery terminal ends and cables, and alternator output.
Codes Related to P0392
