P0391 – Camshaft position (CMP) sensor B, bank 2 circuit range/performance
Last Updated 2016-08-22
P0391 | Camshaft position (CMP) sensor B, bank 2 circuit range/performance | Wiring, poor connection, CMP sensor |
What Does Code P0391 Mean?
If a code P0391 accompanies a malfunction indicator lamp (MIL) in your vehicle, it means that the powertrain control module (PCM) has detected a problem with the exhaust camshaft position sensor (or circuit) for engine bank one. Bank 2 represents the bank of the engine that does not contain the number one cylinder. Sensor B indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the exhaust camshaft.
When the engine is running, the PCM constantly compares input signals from the camshafts and the crankshaft. If the camshaft position is not within a specified degree of variation from the crankshaft and other camshafts, under certain circumstances, for a set period of time, a P0391 code will be stored and a MIL may be illuminated.
What are the common causes of code P0391 ?
What are the symptoms of code P0391 ?
- Diminished fuel efficiency
How do you troubleshoot code P0391 ?
A Range/Performance related code will be set when either a sensor or other component does not perform within the range the PCM (Powertrain Control Module) expects to see, given the current engine load/speed, and information gathered from other sensors. The possible causes of Range/Performance codes are likely to be defective sensors as easily as they are likely to be the result of wiring issues that affect the operation of the affected sensor or component, which means that with these codes, it is important to regard all sensors and components as part of the control circuit the code refers to.
Before attempting to diagnose a code P0391, I would need a suitable diagnostic scanner, a digital volt/ohmmeter (DVOM), possibly an oscilloscope, and access to All Data DIY.
I like to perform a visual inspection of all system related wiring harnesses and connectors before beginning any testing. Wiring circuits, electrical sensors, and/or connectors that have been contaminated with engine oil, coolant, or power steering fluid should be examined carefully for damage. Petroleum based fluids may break down the protective insulation on wiring and lead to shorted or open circuits and a stored P0391. This is also a great time to load test the battery, check battery terminal ends and cables, and alternator output.
Codes Related to P0391
