P0390 – Camshaft position (CMP) sensor B, bank 2 circuit malfunction
Stephen Darby
By Stephen Darby (Contact Me)
Last Updated 2016-08-22
P0390 Camshaft position (CMP) sensor B, bank 2 circuit malfunction
Wiring, poor connection, CMP sensor, ECM
  1. What Does Code P0390 Mean?
  2. What are the common causes of code P0390 ?
  3. What are the symptoms of code P0390 ?
  4. How do you troubleshoot code P0390 ?
  5. Codes Related to P0390
  6. Get Help with P0390
If a code P0390 accompanies a malfunction indicator lamp (MIL) in your vehicle, it means that the powertrain control module (PCM) has detected a problem with the exhaust camshaft position sensor (or circuit) for engine bank one. Bank 2 represents the bank of the engine that does not contain the number one cylinder. Sensor B indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the exhaust camshaft.
CMP sensor
Crank Sensor
When the engine is running, the PCM constantly compares input signals from the camshafts and the crankshaft. If the camshaft position is not within a specified degree of variation from the crankshaft and other camshafts, under certain circumstances, for a set period of time, a P0390 code will be stored and a MIL may be illuminated.
  • Defective camshaft sensor or crankshaft sensor (some manufacturers recommend that these sensors are replaced as a set)
  • Open or shorted wiring to the camshaft sensor
  • Corroded or fluid soaked connector/camshaft sensor
  • Faulty PCM or PCM programming error
  • Hesitation upon acceleration
  • General lack of engine performance
  • Diminished fuel efficiency
  • Due to timing issues, the catalytic converter may become overheated
  • Spark detonation (backfire) when decelerating
  • Spark knock (pinging) when accelerating
“Circuit Malfunction” indicates that there is a malfunction in the control circuit, as opposed to a fault in a sensor or other component. With “Circuit Malfunction” codes, replacement of sensors and components in the affected circuit will almost never resolve the problem, since as the code suggests, the trouble is in the circuit. This distinction between “circuit” and “sensor/component” is a great help to anyone trying to diagnose a circuit malfunction code, since it narrows the list of possible causes down considerably.
Before attempting to diagnose a code P0390, I would need a suitable diagnostic scanner, a digital volt/ohmmeter (DVOM), possibly an oscilloscope, and access to All Data DIY.
CMP Diagram
I like to perform a visual inspection of all system related wiring harnesses and connectors before beginning any testing. Wiring circuits, electrical sensors, and/or connectors that have been contaminated with engine oil, coolant, or power steering fluid should be examined carefully for damage. Petroleum based fluids may break down the protective insulation on wiring and lead to shorted or open circuits and a stored P0390. This is also a great time to load test the battery, check battery terminal ends and cables, and alternator output.
Osc Wave Form
