P0372 – Timing reference, high resolution signal A -too few pulses
| P0372 | Timing reference, high resolution signal A -too few pulses (Buy Part On Amazon) | Wiring, CKP/RPM/CMP sensor, ECM |
Reading P0372 on your car
A basic adapter will show you P0372, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
We have not gotten around to publishing a technical guide specifically for P0372 – Timing reference, high resolution signal A -too few pulses yet.
