P0369 – Camshaft position (CMP) sensor B, bank 1 circuit intermittent
Avatar photo
By Stephen Darby (Contact Me)
Last Updated 2016-08-22
P0369 Camshaft position (CMP) sensor B, bank 1 circuit intermittent
Wiring, poor connection, ECM
  1. What Does Code P0369 Mean?
  2. What are the common causes of code P0369 ?
  3. What are the symptoms of code P0369 ?
  4. How do you troubleshoot code P0369 ?
  5. Codes Related to P0369
  6. Get Help with P0369
If a code P0369 accompanies a malfunction indicator lamp (MIL) in your vehicle, it means that the powertrain control module (PCM) has detected a problem with the exhaust camshaft position sensor (or circuit) for engine bank one. Bank 1 represents the bank of the engine that contains the number one cylinder. Sensor B indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the exhaust camshaft.
CMP sensor
Crank Sensor
When the engine is running, the PCM constantly compares input signals from the camshafts and the crankshaft. If the camshaft position is not within a specified degree of variation from the crankshaft and other camshafts, under certain circumstances, for a set period of time, a P0369 code will be stored and a MIL may be illuminated.
  • Defective camshaft sensor or crankshaft sensor (some manufacturers recommend that these sensors are replaced as a set)
  • Open or shorted wiring to the camshaft sensor
  • Corroded or fluid soaked connector/camshaft sensor
  • Faulty PCM or PCM programming error
  • Hesitation upon acceleration
  • General lack of engine performance
  • Diminished fuel efficiency
  • Due to timing issues, the catalytic converter may become overheated
  • Spark detonation (backfire) when decelerating
  • Spark knock (pinging) when accelerating
Regardless of the code and the system affected, the word “Intermittent” refers to the fact that there is a sporadic, unpredictable, or, well, intermittent fault in that system. The most likely causes of codes that relate to intermittent faults include poor connections in both live and ground circuits, as well defective switches, relays, and sensors.
Before attempting to diagnose a code P0369, I would need a suitable diagnostic scanner, a digital volt/ohmmeter (DVOM), possibly an oscilloscope, and access to All Data DIY.
CMP Diagram
I like to perform a visual inspection of all system related wiring harnesses and connectors before beginning any testing. Wiring circuits, electrical sensors, and/or connectors that have been contaminated with engine oil, coolant, or power steering fluid should be examined carefully for damage. Petroleum based fluids may break down the protective insulation on wiring and lead to shorted or open circuits and a stored P0369. This is also a great time to load test the battery, check battery terminal ends and cables, and alternator output.
Osc Wave Form
