P0368 – Camshaft position (CMP) sensor B, bank 1 circuit high input
Last Updated 2016-08-22
P0368 | Camshaft position (CMP) sensor B, bank 1 circuit high input (Buy Part On Amazon) | Wiring short to positive, CMP sensor, ECM |
What Does Code P0368 Mean?
If a code P0368 accompanies a malfunction indicator lamp (MIL) in your vehicle, it means that the powertrain control module (PCM) has detected a problem with the exhaust camshaft position sensor (or circuit) for engine bank one. Bank 1 represents the bank of the engine that contains the number one cylinder. Sensor B indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the exhaust camshaft.
When the engine is running, the PCM constantly compares input signals from the camshafts and the crankshaft. If the camshaft position is not within a specified degree of variation from the crankshaft and other camshafts, under certain circumstances, for a set period of time, a P0368 code will be stored and a MIL may be illuminated.
What are the common causes of code P0368 ?
What are the symptoms of code P0368 ?
- Diminished fuel efficiency
How do you troubleshoot code P0368 ?
Circuit High Input codes are mostly caused by defective alternators that develop excessive voltages, although there may be other causes as well, such as short circuits that “leak” current into a particular system from other, unrelated systems that work on higher voltages. Note that in the case of short circuits that leak power into a control circuit, there is likely to be other, seemingly unrelated trouble codes present along with the code(s) being investigated. Diagnosing a “high input” code will always involve a thorough testing of the charging system as a first step, followed by measures to isolate the system from all other possible sources of power during resistance, continuity, and reference voltage tests.
Before attempting to diagnose a code P0368, I would need a suitable diagnostic scanner, a digital volt/ohmmeter (DVOM), possibly an oscilloscope, and access to All Data DIY.
I like to perform a visual inspection of all system related wiring harnesses and connectors before beginning any testing. Wiring circuits, electrical sensors, and/or connectors that have been contaminated with engine oil, coolant, or power steering fluid should be examined carefully for damage. Petroleum based fluids may break down the protective insulation on wiring and lead to shorted or open circuits and a stored P0368. This is also a great time to load test the battery, check battery terminal ends and cables, and alternator output.
Codes Related to P0368
Will the camshaft p senser not let fuel pump start or even prime on 2007 Toyota sienna 3.5 engine?
No. It receives a position signal from the camshaft and sends it to the pcm. However, it doesn’t have the parameters to disable fuel.
