P0366 Camshaft Position (CMP) Sensor B Bank 1 Circuit Range/Performance
Last Updated 2016-08-22
P0366 | Camshaft position (CMP) sensor B, bank 1 circuit range/performance | Wiring, poor connection, CMP sensor |
What Does Code P0366 Mean?
If a code P0366 accompanies a malfunction indicator lamp (MIL) in your vehicle, it means that the powertrain control module (PCM) has detected a problem with the exhaust camshaft position sensor (or circuit) for engine bank one. Bank 1 represents the bank of the engine that contains the number one cylinder. Sensor B indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the exhaust camshaft.
When the engine is running, the PCM constantly compares input signals from the camshafts and the crankshaft. If the camshaft position is not within a specified degree of variation from the crankshaft and other camshafts, under certain circumstances, for a set period of time, a P0366 code will be stored and a MIL may be illuminated.
What are the common causes of code P0366 ?
What are the symptoms of code P0366 ?
- Diminished fuel efficiency
How do you troubleshoot code P0366 ?
A Range/Performance related code will be set when either a sensor or other component does not perform within the range the PCM (Powertrain Control Module) expects to see, given the current engine load/speed, and information gathered from other sensors. The possible causes of Range/Performance codes are likely to be defective sensors as easily as they are likely to be the result of wiring issues that affect the operation of the affected sensor or component, which means that with these codes, it is important to regard all sensors and components as part of the control circuit the code refers to.
Before attempting to diagnose a code P0366, I would need a suitable diagnostic scanner, a digital volt/ohmmeter (DVOM), possibly an oscilloscope, and access to All Data DIY.
I like to perform a visual inspection of all system related wiring harnesses and connectors before beginning any testing. Wiring circuits, electrical sensors, and/or connectors that have been contaminated with engine oil, coolant, or power steering fluid should be examined carefully for damage. Petroleum based fluids may break down the protective insulation on wiring and lead to shorted or open circuits and a stored P0366. This is also a great time to load test the battery, check battery terminal ends and cables, and alternator output.
Codes Related to P0366
BAT Team Discussions for P0366
- 95 T100 with MIL PO336 engine starts but goes into fail safe?
According to my source, P0366 is for crank sensor range/ performance. Detected condition is... Deviation in crank sensor signal and cam sensor signal Trouble areas could be... Valve timing...Distributor installation...ECM This code will activate fail-safe function, stopping the fuel injection. ... - Caliber Cam sensor, which is which
Car was driving interstate speed for 30 mins then shut down they got the car started in limp mode And started throwing parts at it PCM has 20 codes! I may just start looking for bad grounds. P0366 P0315 P0522 P0507 P0573 P2302 P2308 P2311 P2017 P0113 P0369 P0335 The rest show pending due to bein...
Replaced camshaft sensor and still got same code.p0366.wudup?
Richard,
Did you test for reference voltage and a ground at the crank sensor connector?
Check reference voltage and ground at the cam & crank sensors.
Where it falls and what shape it can picture chevrolet sonic 2012 p0366
P0366
Code big problem ?
