P0365 – Camshaft position (CMP) sensor B, bank 1 circuit malfunction
Last Updated 2016-08-22
P0365 | Camshaft position (CMP) sensor B, bank 1 circuit malfunction (Buy Part On Amazon) | Wiring, poor connection, CMP sensor, ECM |
What Does Code P0365 Mean?
If a code P0365 accompanies a malfunction indicator lamp (MIL) in your vehicle, it means that the powertrain control module (PCM) has detected a problem with the exhaust camshaft position sensor (or circuit) for engine bank one. Bank 1 represents the bank of the engine that contains the number one cylinder. Sensor B indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the exhaust camshaft.
When the engine is running, the PCM constantly compares input signals from the camshafts and the crankshaft. If the camshaft position is not within a specified degree of variation from the crankshaft and other camshafts, under certain circumstances, for a set period of time, a P0365 code will be stored and a MIL may be illuminated.
What are the common causes of code P0365 ?
What are the symptoms of code P0365 ?
- Diminished fuel efficiency
How do you troubleshoot code P0365 ?
“Circuit Malfunction” indicates that there is a malfunction in the control circuit, as opposed to a fault in a sensor or other component. With “Circuit Malfunction” codes, replacement of sensors and components in the affected circuit will almost never resolve the problem, since as the code suggests, the trouble is in the circuit. This distinction between “circuit” and “sensor/component” is a great help to anyone trying to diagnose a circuit malfunction code, since it narrows the list of possible causes down considerably.
Before attempting to diagnose a code P0365, I would need a suitable diagnostic scanner, a digital volt/ohmmeter (DVOM), possibly an oscilloscope, and access to All Data DIY.
I like to perform a visual inspection of all system related wiring harnesses and connectors before beginning any testing. Wiring circuits, electrical sensors, and/or connectors that have been contaminated with engine oil, coolant, or power steering fluid should be examined carefully for damage. Petroleum based fluids may break down the protective insulation on wiring and lead to shorted or open circuits and a stored P0365. This is also a great time to load test the battery, check battery terminal ends and cables, and alternator output.
Codes Related to P0365
Is the engine timed correctly? If so, you might check for a TSB pertaining to syncing the CMP/s and the CKP. I can remember a car that I had to replace the cam sensor and crank sensor as a set (from Nissan). Just a suggestion.
If that doesn’t help, gain access to an oscilloscope and get ready to study some waveform voltage patterns. If the problem only occurs under cold start, that makes it even more difficult.
Good luck.
I am getting the po365 code on my 2007 solstice with a 2.4 liter.
It is still running okay but occasionally is hard to start.
I have changed both camshaft sensors and still have the same problem.
Suggestions?
