P0361 – Ignition coil K, primary/secondary -circuit malfunction
Mia
By Mia (Contact Me)
Last Updated 2016-06-23
P0361 Ignition coil K, primary/secondary -circuit malfunction
Wiring, ignition coil, ECM
  1. What Does Code P0361 Mean?
  2. What are the common causes of code P0361 ?
  3. What are the symptoms of code P0361 ?
  4. How do you troubleshoot code P0361 ?
  5. Codes Related to P0361
  6. Get Help with P0361
coil-pack
A coil pack
(Courtesy: www.ngk.de)
The PCM sets an ignition coil control circuit code P0350 to P0362 when it detects a problem with the ignition coil circuit. The last digit of these codes references the cylinder where the issue is occurring. For example, P0351 indicates a fault in the #1 cylinder coil circuit. Likewise, P0361 indicates a problem with the coil circuit on cylinder #11 on a V12 engine.
To sum things up, the common causes for code P0361 are as follows:
  • Faulty ignition coil
  • Problem in the ignition coil circuit
  • Problem with the PCM
In addition to an illuminated check engine light, the most common symptom is an ignition misfire. Often, P0361 codes will also be accompanied by a misfire code P0311.
The following steps will help you diagnose a P0361 code:
  • Visually inspect the coil pack and it’s connector
  • Swap coil packs
  • Test the coil
testing-coil-resistance
Testing coil resistance
(Courtesy: autozone.com)
  • Check for power
ignition-wiring-schematic
(Courtesy: AllData)
  • Test the PCM control circuit
  • DTC P0351: Ignition coil control circuit – Cylinder 1
  • DTC P0352: Ignition coil control circuit – Cylinder 2
  • DTC P0353: Ignition coil control circuit – Cylinder 3
  • DTC P0354: Ignition coil control circuit – Cylinder 4
  • DTC P0355: Ignition coil control circuit – Cylinder 5
  • DTC P0356: Ignition coil control circuit – Cylinder 6
  • DTC P0357: Ignition coil control circuit – Cylinder 7
  • DTC P0358: Ignition coil control circuit – Cylinder 8
  • DTC P0359: Ignition coil control circuit – Cylinder 9
  • DTC P0360: Ignition coil control circuit – Cylinder 10
  • DTC P0361: Ignition coil control circuit – Cylinder 11
  • DTC P0362: Ignition coil control circuit – Cylinder 12
