P0360 – Ignition coil J, primary/secondary -circuit malfunction
Last Updated 2016-06-23
P0360 | Ignition coil J, primary/secondary -circuit malfunction (Buy Part On Amazon) | Wiring, ignition coil, ECM |
What Does Code P0360 Mean?
A coil pack
(Courtesy: www.ngk.de)
The PCM sets an ignition coil control circuit code P0350 to P0362 when it detects a problem with the ignition coil circuit. The last digit of these codes references the cylinder where the issue is occurring. For example, P0351 indicates a fault in the #1 cylinder coil circuit. Likewise, P0360 indicates a problem with the coil circuit on cylinder #10 on a V10 or V12 engine.
What are the common causes of code P0360 ?
To sum things up, the common causes for code P0360 are as follows:
- Faulty ignition coil
- Problem with the PCM
What are the symptoms of code P0360 ?
In addition to an illuminated check engine light, the most common symptom is an ignition misfire. Often, P0360 codes will also be accompanied by a misfire code P0310.
How do you troubleshoot code P0360 ?
The following steps will help you diagnose a P0360 code:
- Swap coil packs
- Test the coil
Testing coil resistance
(Courtesy: autozone.com)
- Check for power
(Courtesy: AllData)
Codes Related to P0360
Getting this code on a V8 2005 Pontiac GTO LS2 but this code is for a cylinder that doesn’t exist? Anybody have any ideas? Also pulling a p0156 code also thank you
