P0359 – Ignition coil I, primary/secondary -circuit malfunction
Last Updated 2016-06-23
P0359 | Ignition coil I, primary/secondary -circuit malfunction (Buy Part On Amazon) | Wiring, ignition coil, ECM |
What Does Code P0359 Mean?
A coil pack
(Courtesy: www.ngk.de)
The PCM sets an ignition coil control circuit code P0350 to P0362 when it detects a problem with the ignition coil circuit. The last digit of these codes references the cylinder where the issue is occurring. For example, P0351 indicates a fault in the #1 cylinder coil circuit. Likewise, P0359 indicates a problem with the coil circuit on cylinder #9 on a V10 or V12 engine.
What are the common causes of code P0359 ?
To sum things up, the common causes for code P0359 are as follows:
- Faulty ignition coil
- Problem with the PCM
What are the symptoms of code P0359 ?
In addition to an illuminated check engine light, the most common symptom is an ignition misfire. Often, P0359 codes will also be accompanied by a misfire code P0309.
How do you troubleshoot code P0359 ?
The following steps will help you diagnose a P0359 code:
- Swap coil packs
- Test the coil
Testing coil resistance
(Courtesy: autozone.com)
- Check for power
(Courtesy: AllData)
Codes Related to P0359
