P0358 – Ignition coil H, primary/secondary -circuit malfunction
Last Updated 2017-01-26
P0358 | Ignition coil H, primary/secondary -circuit malfunction (Buy Part On Amazon) | Wiring, ignition coil, ECM |
What Does Code P0358 Mean?
A coil pack
(Courtesy: www.ngk.de)
What are the common causes of code P0358 ?
To sum things up, the common causes for code P0358 are as follows:
- Faulty ignition coil
- Problem with the PCM
What are the symptoms of code P0358 ?
How do you troubleshoot code P0358 ?
- Swap coil packs
- Test the coil
Testing coil resistance
(Courtesy: autozone.com)
- Check for power
(Courtesy: AllData)
Codes Related to P0358
What does the Ignition Coil H mean?
