P0355 – Ignition coil E, primary/secondary -circuit malfunction
Last Updated 2017-01-26
P0355 | Ignition coil E, primary/secondary -circuit malfunction (Buy Part On Amazon) | Wiring, ignition coil, ECM |
What Does Code P0355 Mean?
A coil pack
(Courtesy: www.ngk.de)
What are the common causes of code P0355 ?
To sum things up, the common causes for code P0355 are as follows:
- Faulty ignition coil
- Problem with the PCM
What are the symptoms of code P0355 ?
How do you troubleshoot code P0355 ?
- Swap coil packs
- Test the coil
Testing coil resistance
(Courtesy: autozone.com)
- Check for power
(Courtesy: AllData)
Codes Related to P0355
Using the OBII tester I initially found my car #1 cylinder was bad. I performed the ”Coil switch” check to confirm it. So I replaced all the coils. The next day the check engine light came on again. This time my reader showed PO355. I didn’t know what this meant until I read this article that it was an issue with my #5 coil. I’ll Verify today if it’s a defective coil and replace it. Thank you for the website and information.
My 2003 Jeep Liberty 3.7 v6 keep melting cylinder number 5 coil every time I plug it up and run it all the other coils are fine the check engine light staying on code po355 is set and the Electric fan motor for the motor works when I jump start it but it has no ground to it is why it not running wile the motor is running what is causing the problems with the coil on cylinder 5 to melt and no ground to the fan motor for the motor what is the problem the PCM or a Ground coming to the cylinder number 5
I have a 2006 Ford Fusion that is running very rough. The mechanic said it is throwing a PO355 code and he is doing some research on it.
The car runs great out on the road at speeds in excess of 50 MPH however at lower speeds or when idling it will run so rough (backfiring intermittently)that the engine jumps so much it has thrown a serpentine belt.
Anyone have any Ideas that might help?
