P0353 – Ignition coil C, primary/secondary -circuit malfunction
| P0353 | Ignition coil C, primary/secondary -circuit malfunction (Buy Part On Amazon) | Wiring, ignition coil, ECM |
Where is the Ignition Coil? See our guide to the Ignition Coil – what it does, where it sits on the engine and how it fails.
- What Does Code P0353 Mean?
- What are the common causes of code P0353 ?
- What are the symptoms of code P0353 ?
- How do you troubleshoot code P0353 ?
- Codes Related to P0353
- Get Help with P0353
A coil pack
(Courtesy: www.ngk.de)
To sum things up, the common causes for code P0353 are as follows:
- Faulty ignition coil
- Problem with the PCM
- Swap coil packs
- Test the coil
Testing coil resistance
(Courtesy: autozone.com)
- Check for power
(Courtesy: AllData)
Reading P0353 on your car
A basic adapter will show you P0353, but not the ABS, airbag or transmission modules, and not the bidirectional tests that confirm which part has actually failed rather than which circuit reported it.
I have 2002 chys 300m. Getting codes p0300, p0351, p0353 with a knock in engine. Its not consistent knock and goes away when i accelerate. Can someone please help me
How to troubleshoot P0353 sir? Pls. Help me
My car is melting coil #3 any help with that
Hi I have problem with my Zafira with code P0350 it’s misfire on 3 wale I check coil pack it’s ok wires it’s ok can I ask if the maybe possible problem in ECU ?
Vlado-
Usually, I would say swap coils 3 and 4 and see if the DTC follows the coil, but I think this is the one with the 4-in-1 ignition coil pack, isn’t it? From what I can tell, you should be able to test resistance, 0.6 Ω between PWR and each ground. I would think if there’s any discrepancy between these readings, then you’d have to replace the coil pack. Be sure to check for circuit problems between the ECM and the coil pack.
