P0352 – Ignition coil B, primary/secondary -circuit malfunction
Last Updated 2016-01-28
P0352 | Ignition coil B, primary/secondary -circuit malfunction (Buy Part On Amazon) | Wiring, ignition coil, ECM |
What Does Code P0352 Mean?
A coil pack
(Courtesy: www.ngk.de)
What are the common causes of code P0352 ?
To sum things up, the common causes for code P0352 are as follows:
- Faulty ignition coil
- Problem with the PCM
What are the symptoms of code P0352 ?
How do you troubleshoot code P0352 ?
- Swap coil packs
- Test the coil
Testing coil resistance
(Courtesy: autozone.com)
- Check for power
(Courtesy: AllData)
Codes Related to P0352
This was extremely helpful. I really didn’t want to give the dealer hundreds of dollars (they are friends of my wife so if car needs work that I can’t do it goes there). It looks like I can get the coild replaced for under $50.00
Thanks Again
Thank you very much for your expertise and making this very useful article available. You could have saved me more than few hundred bucks.
I have a jaguar 1999 3.2 v8 And when I drive carefully it is sweet but put my foot down it goes into limp mode I turn engine off for 20 min it’s ok again !! Help please
