P0351 – Ignition coil A, primary/secondary -circuit malfunction
Last Updated 2017-01-26
P0351 | Ignition coil A, primary/secondary -circuit malfunction (Buy Part On Amazon) | Wiring, ignition coil, ECM |
What Does Code P0351 Mean?
A coil pack
(Courtesy: www.ngk.de)
What are the common causes of code P0351 ?
To sum things up, the common causes for code P0351 are as follows:
- Faulty ignition coil
- Problem with the PCM
What are the symptoms of code P0351 ?
How do you troubleshoot code P0351 ?
- Swap coil packs
- Test the coil
Testing coil resistance
(Courtesy: autozone.com)
- Check for power
(Courtesy: AllData)
Codes Related to P0351
[…] looked up Troublecodes.net and showed me all I needed to know about the error code which was P0351, invaluable information so I knew whether to keep driving the car or […]
Mi coche falla por las mañanas cuando lo prendo, siento que se ahoga al momento de prender pero después cuando calienta normal todo el día.
Last night we pressure washed the engine on 2001 Dodge Dakota 4.7 V8, and now we have codes flashing. They are P0351, P0354, P0300, P0301, P0307, P0308, P0357. Yesterday it ran perfect and this morning when we started it, it was extremely rough. Any ideas?
REPLACE THE PCM THAT’S THE PROBLEM
what is pcm on 1998 jeep grand cherokee laredo po351
Ranault scenic ii won’t start and is reading codes0354 n 0351 have jus changed coils 1 n 4 but still persist with d problem ways the next step is it the ecm unit
