P0350 – Ignition coil, primary/secondary -circuit malfunction
P0350 | Ignition coil, primary/secondary -circuit malfunction (Buy Part On Amazon) | Wiring, ignition coil, ECM |
- What Does Code P0350 Mean?
- What are the common causes of code P0350 ?
- What are the symptoms of code P0350 ?
- How do you troubleshoot code P0350 ?
- Codes Related to P0350
- Get Help with P0350
A coil pack
(Courtesy: www.ngk.de)
To sum things up, the common causes for code P0350 are as follows:
- Faulty ignition coil
- Problem with the PCM. PCM problems are the least likely cause. Some Ford cars, such as the 3.0L Ford Fusion and Ford Escape were known to have faulty PCMs.
- Swap coil packs
- Test the coil
Testing coil resistance
(Courtesy: autozone.com)
- Check for power
(Courtesy: AllData)
My 2002 hyundai santa fe 4 cy has a PO350 n PO350p what is the PO350p? engine idle rough now
Hello,
I use an infinity FX35 and recently the ignition coils keep on burning, at least every 2 days; I took it to a mechanic and this error code above and other errors like P113 IAT, p0031 hO2S1, an P0550 pW show up, he replaced the crankshaft sensor and the air flow sensor and the issue is gone for about 2weeks, unfortunately I got it again yesterday, any hint?
There is a technical service bulletin (TSB) regarding this issue which might solve your problem. The TSB is number ITB11-017 and it states if the ignition coils are blistered to replace the steering member mounting bolt on the right side of the instrument panel, clean the engine harness grounds and replace both negative battery cables.
Is this a part that can malfunction when the engine is cold and then behave normal when the engine is warm? My problem is in the mornings after the engine has been off for several hours. It just won’t start for a long time sometimes requires runs the battery flat
Paul-
Yes, cold does funny things to electronics and the plastics they’re mounted in, leading to short circuits, open circuits, and the like. The problem is that P0350 means random fault, so it could refer to any and all of the coils, so we need to look at something that affects ALL of the coils. You might need to see what relay feeds those coils, as that might be malfunctioning in the cold. Also, double-check the connectors between the coil and the ECM or ignition controller. What vehicle are you working on? Do you have any pending misfire codes at the same time?
interesting ! random fault p0350 , last year I replaced all4coils and spark plugs. one year later, p0350, random. never thought of theRELAY ! BEN,YOU JUST MIGHT BE MY SAVIOR !
