P0347 – Camshaft position (CMP) sensor A, bank 2 -low input
P0347 | Camshaft position (CMP) sensor A, bank 2 -low input (Buy Part On Amazon) | Wiring short to earth, CMP sensor, ECM |
- What Does Code P0347 Mean?
- What are the common causes of code P0347 ?
- What are the symptoms of code P0347 ?
- How do you troubleshoot code P0347 ?
- Codes Related to P0347
- Get Help with P0347
The camshaft position sensor reacts to a toothed wheel on the camshaft, which gives the ECU constant information on its speed and position. Of course, the CMP is located on the engine, usually somewhere on the cylinder head, so it transmits CMP data to the ECU using wires. If the ECU detects a low resistance (short circuit), it will set DTC P0342 or DTC P0347 – Camshaft Position Sensor Low Input. If your engine has only one CMP, such as an inline-four-cylinder, the only CMP code available is for Bank 1, P0342. On the other hand, V6 or V8 engines have two banks, Bank 1 and Bank 2, and would therefore have two CMPs, so DTC P0347 would refer to Bank 2. Sensor A indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the intake camshaft. Sensor B codes pertain to the exhaust camshaft.
Depending on year, make, and model, DTC P0342 or P0347 may have number of causes. Here are some of the most common.
Ford Trucks / Mustang GT – An alternator phase problem, such as a blown diode or open coil, may cause so much electrical interference that the CMP signal gets distorted, causing a P0342 / P0347 DTC to set, among others, in spite of there being no actual problem with the CMP sensor or wiring.
Because P0342 and P0347 refer to a circuit problem, do not automatically condemn the CMP sensor. That’s not to say that it might not be the sensor itself, but replacing the sensor is not always going to fix the problem. Get out your wiring diagram and DVOM (digital volt-ohm meter) for this next part.
- Sensor Inspection
- Other Problems – In case no problems can be found in the CMP sensor or its wiring, it may be that P0342 or P0347 are simply auxiliary fault codes. A jumped timing belt, faulty crankshaft position sensor signal or circuit, or engine misfire, may be the primary problem. Double check these before coming back to the CMP.
DTC P0342 or P0347 may be accompanied by other DTCs, such as P0300 Random Misfire, P0725 Engine Speed Sensor Circuit, or P0335 Crankshaft Position Sensor Circuit Malfunction.
