P0345 – Camshaft position (CMP) sensor A, bank 2 circuit malfunction
Last Updated 2016-08-22
P0345 | Camshaft position (CMP) sensor A, bank 2 circuit malfunction | Wiring, CMP sensor, ECM |
What Does Code P0345 Mean?
The camshaft position sensor reacts to a toothed wheel on the camshaft, which gives the ECU constant information on its speed and position. Of course, the CMP is located on the engine, usually somewhere on the cylinder head, so it transmits CMP data to the ECU using wires. If the ECU cannot detect a CMP signal, it will set DTC P0340 or DTC P0345 – Camshaft Position Sensor Circuit Malfunction. If your engine has only one CMP, such as an inline-four-cylinder, the only CMP code available is for Bank 1, P0340. On the other hand, V6 or V8 engines have two banks, Bank 1 and Bank 2, and would therefore have two CMPs, so DTC P0345 would refer to Bank 2. Sensor A indicates that the malfunction is occurring with the camshaft position sensor circuit that pertains to the intake camshaft. Sensor B codes pertain to the exhaust camshaft.
What are the common causes of code P0345 ?
Depending on year, make, and model, DTC P0340 or P0345 may have number of causes. Here are some of the most common.
Ford Trucks / Mustang GT – An alternator phase problem, such as a blown diode or open coil, may cause so much electrical interference that the CMP signal gets distorted, causing a P0340 / P0345 DTC to set, among others, in spite of there being no actual problem with the CMP sensor or wiring.
What are the symptoms of code P0345 ?
How do you troubleshoot code P0345 ?
Because P0340 and P0345 refer to a circuit problem, do not automatically condemn the CMP sensor. That’s not to say that it might not be the sensor itself, but replacing the sensor is not always going to fix the problem. Get out your wiring diagram and DVOM (digital volt-ohm meter) for this next part.
- Sensor Inspection
- Other Problems – In case no problems can be found in the CMP sensor or its wiring, it may be that P0340 or P0345 are simply auxiliary fault codes. A jumped timing belt, faulty crankshaft position sensor signal or circuit, or engine misfire, may be the primary problem. Double check these before coming back to the CMP.
Codes Related to P0345
DTC P0340 or P0345 may be accompanied by other DTCs, such as P0300 Random Misfire, P0725 Engine Speed Sensor Circuit, or P0335 Crankshaft Position Sensor Circuit Malfunction.
BAT Team Discussions for P0345
- 2006 Lexus GS300 AWD stalled while driving
My daughter driving and comes to a stop at stoplight and cars dies? Tried restarting and engine would crank but not start. After pushing car to side of road someone tried to jumpstart and didn’t work. She had car towed home following day and tow guys tried to start and starts right up? He says it...
ich habe F-430 motortausch,jetzt leuchtet CAT LAMPE wnn mit TESTER GELÖSCHT lampe weg 1 Minute wieder da.
MOTORLEISTUNG PEREKT ,ICH HABE: sensoren auf dem zylinderkopfdeckel getauscht kein erfolg,alle drähte komntrolliert
mein tester zeigt dieses bild
How do i get schematic for wiring from ecm to cam sensor on 5.4 3valve ford f150
Refer to the service manual to find specific wiring diagrams for specific vehicles. Generally speaking, there will be a section dedicated to electrical diagrams.
I unplugged my pass side (new sensor) and my 08FX4 is better. Not 100%,but 90%. Did my chain jump on bank 2? Pass side is the codes and the noise. Changed both cam phasers. I’m at the end of my chain.
Can you tell us what software you have on the laptop that you displayed in your video of P0345 error codes? Thanks
